Hi All - A while back I read something about using a garden cart for a dolly.
http://www.lowes.com/lkn?action=productDetail&productId=128483-28801-21922
Since I was less than a day away from my first shoot I went to my local Lowes and picked one up. After putting it together I did some test with my tripod attached securely with a number of bungee straps. I was fairly pleased with the results but thought that I needed to add some weight. So I added 200 lbs of play sand (four 50lb. bags) We used the dolly for 2 shots the next morning and the results were fantastic. We rolled over a number of sidewalk cracks and the final image is glass smooth. I took the advice of the person who originally pointed this cart out to me and let some of the air out of the tires to smoothen the ride even more.
The cart holds 1200 lbs and is large enough to ride on if a shot requires hand holding. The cart also works great to haul your equipment around on. You can take the sides off of this cart as well. (as we did.)
Dave
Dave
