cyvideo
Sony themselves have stated the variable ND fitted to many Sony cameras does introduce a colour shift that changes depending on how much ND you use. Sony explained it with comments along the lines of: "When using Sony E-Mount lenses that communicate with the camera's software the software adds an offset to the WB as you switch the ND in or out and or change the amount of ND. Generally you are not aware of these color shifts as they are dynamically being corrected for in real time as you add or adjust the eND."
If you watch carefully when you engage or disengage the eND you can sometimes glimpse a fraction of a second where the camera's electronic offset that corrects for the shift is applied just as the filter comes in. It's like adding a WB offset in the WB offset menu manually, but this is an eND WB offset which is added in real time. Then, once the filter is in place, the colours appear completely normal again.
All this auto WB offsetting along with any lens distortion correction, peripheral illumination and CA correction comes into effect when using Sony lenses that communicate with the camera software. This does not happen when using non-electronic lenses that do not communicate with the camera. This is the main reason why the Venice does not run eND and why the engineers developed the Venice's wide range dual filter servo-controlled 8-step mechanical ND filter system. Claudio Miranda made the comment when shooting with the Venice 2 that he observed no change in colorimetry between ND3 all the way to 2.4. Most modern cine lenses carry ARRI's LDS and Cooke's i Technology Protocol, but these have no relationship to the protocols built into the Sony cameras that run E-Mount with eND and WB offsetting along with their associated lens corrections. The eND is an amazing tool for a variety of reasons. DOF and light control being the main reasons, along with the quicker workflow of not having to carry external filtration and the rigging to run that. i.e. matte boxes and the like. All great pluses in my opinion. For all the eND's pluses though, I have seen some things in post that I have never seen before with regular full field flat glass NDs. Firstly, I've now seen two FX9 cameras that developed some odd flickering in their eND filters. Both those operators had to get the eNDs replaced in their cameras. And secondly, a PXW-Z190 that suffered some kind of eND filter damage when shooting the sun. You make up your own choices to suit your workflow, balancing all the plus, minus factors against that workflow. Overall for me the eND is 9.9/10 in most cases. So much so that I have sold my 4x 56" filters as they were gathering dust most of the time.
Chris Young
Chris Young
