FS700/Odyssey 7q setup
boosh
Hey guys,
I've been using an FS700 and Odyssey 7q for a couple of years now. I've been fairly pleased with my setup, using a Eldekrone hot shoe style mount to hold the odyssey but for longer form documentary style stuff where I shoot a lot of handheld I find the rig unbalanced when I want to shoot handheld stuff with a mic mounted. I was thinking of taking the top handle off to add a cheese plate and then adding a couple of hot shoes to this to mount the odyssey and a shockmount for a mic and just not having a top handle. Just wondered if anyone had setup anything similar? or had any recommendations?
Thanks,
Paul
Hey guys,
Thanks,
Paul
https://youtu.be/h31tGNoVsaQ
Here is my setup. I just added a lightweight ultra clamp system to replace the DIY handle extension and that saves a bit of weight. I find this system to be very balanced.
Wow that's your Set up aumen? Its really weird I was in the first 20 people to view that video back in December and little did I know it was by a dvx'r. The follow focus hand rest I thought was a very cool idea and I still have yet to see a more comfortable grip position. Could you use it with a follow focus lever? I ask because it doesn't seem like that would be possible.
Also back to the topic at hand, I like the rosette adapters and think they are extremely sturdy. It will require a special frame for the 7q, rosette bracket extender and 15mm clamp connector to put it from for the odyssey to a rig. A counter balance on the opposite side to displace the weight on a shoulder rig is also useful but for these reasons I probably wouldn't invest in our go for the aforementioned setup. Just food for thought.
How are you dealing with the latency of any monitor but the built in one? Using HDMI it's really bad, and with the Odyssey using raw it seems a bit better but still it's quite a lot. Watching people talk with that delay makes my head ache and for faster moving subjects it's really hard to follow as you are always a few frames behind...
I have never used a focus lever but I am super happy with the hand rest. It makes most focus pulls really easy...for longer pulls, I sometimes rely on an AC with a whip depending on the shot.
ea-
nice vid.
very helpful.
fs700 + ody7q is still a winning combo not made totally obsolete by either the fs7 or the fs5.
ymmv.
be well.
rob
smalltalk.productions
Glad you found some useful info in there. There is nothing on the comparable owner/op market that warrants spending more money compared to the specs this combo can do (IMHO).
