Nope, there from day 1....Woah, was this added in a later firmware?
This does make the C300 look tempting. Have been pondering a visual upgrade from my FS7 for a while. Skin color, and codec being the two reasons.
Is it possible to use the Viewfinder with a 15mm rod, instead of the square one? I'm thinking I'd like to mount it to a CineArm or Zamerican Arm.
2K 4:4:4 is def my top wish for future cameras. The benefits of a proper downsample in camera have great potential.
Mitch
I guess you still need a silly box on the rear of the fs7ii to hoot raw?
Hi Mitch,
want to ask if you tried the FS7II with the Odyssey. Is the RAW truly 12bit or is 10-11 bits as someone pointed out? Did sony fixed that issue?
Thanks, you are awesome!
If you can get the "equivalent" of 10-bit RGB 2K from 8-bit 4:2:2 4K by transcoding in post properly, I would think the same would be true for getting "equivalent" 12-bit RGB from 10-bit 4:2:2 4K? I've never needed true RGB footage for any reason, so I haven't looked into it (or touched the SR codec on the F5). Maybe Mitch could speak to this equivalency... it's a little over my head right now.
