Harry Lime
Not to search through long thread, could you explain me how RAW data can have log curve?
RAW data is the measured value of voltage produced by photo-sites of the camera sensor, without any processing or manipulation.
To maximize the tonal range of a sensor, log curve can be applied to deliberately remove parts of the image data.
Alexa sensor is 14-bit linear, internal processing is 16-bit and ARRIRAW data is efficiently stored as 12-bit log to retain 14(+) stops of latitude.
To create "16"-bit RGB image, applying reverse curve is a part of performed colour science, followed by final step of debayering.
And all of that with just 1/3 of the required bandwidth. Primary goal of RAW was not safety net for bad DP.
To go back to the FS7 12-bit linear < 12-bit log claim, it's not that simple.
Sony use floating point for storing data in 12-bit linear RAW, otherwise it wouldn't be possible to fit 14 stops.
Limitation is that amount of data available for the shadows is very small.
Data rounding used to retain the whole latitude of the sensor in 12-bit linear resulted in the coarser luma steps in the first two to three stops.
Solution to this is to overexpose up to 2 stops.
Log version has problems above middle grey and it gets worse and worse since each brighter stop has the same limited amount of data.
And without enough light footage will be noisy.
To conclude, 12-bit for "Real World" examples is just fine, for vfx get 16 bit.
I can't explain the math to you. I just make pretty pictures. I'll see if I can dig up the thread, which went into a lot of technical details.
