I'm just about to buy a FS100 (with much help from this forum) and am wondering about adding a Ninja to my order. The project I"m working on is in the bush in Africa. The FS100 is the "B" camera – Sony 800 is the "A" camera – and the FS100 will be used for run-and-gun. I know FS100 is not the perfect beast for running around baobobs, but for the first shoot I was using a 5D and at least with the FS100, I won't spend so much time syncing. The producer plans to do an Academy run next year, meaning that the documentary will be projected at some point.
Right now I'm planning on purchasing the Sony HXR_FMU128_Flash_Memory_Unit, but I'm wondering if it might make more sense to buy a Ninja instead. I know they do completely different things. We're shooting 1080p 24 and I plan to do some 1080p 60. I realize that the Ninja doesn't really do 24P natively (it takes in the 24P at 1080i 60 and then you have to run it through the Ninja "Stripper" app). And, of course, like all the other digital recorders, it doesn't do 1080p 60 at all.
So . . . . Knowing that I'm shooting 24P and will definitely shoot some 1080p 60 for slow motion, does running everything into a Ninja gain me all that much in image quality to buy the Ninja? Will it help out appreciably down the road when we're color grading the footage?
Also, if you would recommend getting the Ninja, which SSD would you recommend (I don't think it makes sense to use HD for this kind of thing)
Thanks.
Thanks.
