Danielisnotadrummer
Today, I'm buying either the HPX170 or the EX1.
Someone help me.
a list of grievances against the ex1, as far as I know:
Rolling shutter
Blue digital look, not as approachable as film
CMOS vs. CCD
lower color sampling
Format not adopted in as many NLE's as DVCPRO hd
Interframe compression
LONG GOP
I'm really in a bind. I have the money to buy the EX1. I've shot numerous features and docs with the hvx200. DVCPROHD's intraframe compression is a huge factor, as well. It's so much easier to edit with. I don't know how I feel about the EX1's long GOP...I thought we were trying to get away with that, with all the problems a long GOP caused in HDV. I love the way the HVX renders motion. I always shoot in 720p24pN and I stay as far away as I can from interlaced (I hate interlacing..so messy).
I walked into AbleCineTech today and the salesmen there practically laughed at me for wanting the HPX170 over the EX1, saying it used an "archaic format and media" and that that images on the EX1 were twice as sharp and everything. i told him i'd be sticking a 35mm adapter with some Zeiss glass on the front and then he said the HPX wouldn't be able to even pick up the amount of detail and the fine nuances of the zeiss glass and that I should buy cheaper glass if I'm using the HPX. He also called it "a sad excuse for an EX1 competitor." can you believe that? It seemed to me as bias, but were his claims valid? is the EX TRULY a better camcorder in EVERY way?
I mean, I've seen the Jello vision rollling shutter artifacts, and let me tell you, they're gross. I even tested out the EX at Able and I did some quick panning and sure enough, jello vision. Considering I do action films and visual effects in post (compositing, motion tracking, ect) shouldnt I prefer a global shutter over a rolling one?
It just really frusterated me how he approached it. He definitely got me doubting the EX. I mean, aside from resolution, I know the HPX has a far better signal to noise ratio than the HVX, and that it's cleaner. So in that case is it really worth it to buy an EX for a couple hundred more lines of resolution? I've always liked the filmic images coming out of the HVX200 and 200a camp. And it seems like most shorts and indies are shot with HVX+adapter rigs. I haven't seen the EX1 in action, in that way.
But to each his own.
So again i'll summarize
I'll be using the camera for LOTS of short film work with 35mm adapter out front with some high quality zeiss primes.
Which camera will achieve the best film look this way?
Someone help me.
Rolling shutter
CMOS vs. CCD
LONG GOP
