from HVX Direct to Power Book G 4 FCP, non controled device, instead of capture on p2 card, is that the same quality as saving to p2 card? If it is I can have my powerbook at the shoot and just capture directly in to fcp. But is that true HD footage?
It's blue because that option is not available / applicable. If you are recording in 720 or 1080, the codec is fixed at DVCProHD and the recording format option is disabled, showing you the last setting that was used. It's a little confusing, but covered in the manual (and Barry's book).
Hey Kevin,
I have never even attempted direct recording but need to do some tests.
Are you recording direct to FCP through a FW cable to your PB 1.67 to a FW 800 drive?
Could you give a quick workflow or set up map. Any insight would be great.
Thanks, Ray
