ullanta
Lately I've been experiencing a lot of errors while formatting SDHC cards in my AC130. I've never had an error once a card is formatted, and I've seen no errors or problems using the same cards in the HMC150, or in torture-testing them via a computer. The same card will sometimes format after a second try in the 130 (then work fine), sometimes not. Sometimes if i try to format a second time, I get an error that says I have to replace the battery or connect AC Power to recover. All very strange.
1) Anyone experiencing anything similar?
2) The AC130 takes much, much longer to format a card than the HMC150 (haven't timed it yet, but I'd guess 5-10 times longer... on the order of a minute per card). Is this common?
3) The folder structure after a card format is a little different from the HMC150... there are two additional folders (DCIM and MISC, IIRC) at the same level as the PRIVATE folder. I haven't had any trouble switching cards formatted in one camera to the other. Has anyone else? Is this a practice that's either OKd or not recommended?
