ydgmdlu
It's the other way around, in my opinion. I'm hypothesizing that the frame rate is created from the sensor scan rate.Mmmm... so the sensor scan rate is dependant on frame rate...
If I'm correct and frame rate is derived from the scan rate, then the scan rate would need to be a multiple of the frame rate, which is why 60 Hz wouldn't work. The scan rate for 60 fps probably isn't 60 Hz anyway; that was just a number that I used for the sake of argument. It's probably 120 Hz (for 60 fps). Also, we don't know that the sensor is capable of scanning that fast. Why would you assume that? The 7D and the GH1 both have very different sensor designs from the 5D and from each other.Is there any reason why it couldn't select a scan rate of 60Hz for 24fps which would give it the same amount of skew/jello as for 60fps... because (for the GH1 abd 7D at least) the sensor is capable of the faster scanning?
If you're wondering why the sensor couldn't just scan at the same maximum rate for all frame rates, then you've missed the whole point. I'm saying that the frame rate is tied to the read-refresh clock. In order to change the frame rate, you have to re-time the clock. That's why you can't use, for example, 120 Hz for all frame rates. Each frame rate must have its own clock speed.
Nobody here, that we know, is a Canon engineer who worked on the camera. So nobody can really answer your questions to your satisfaction. I started this thread merely to offer an explanation for the differing amounts of jello seen at different frame rates. There's no point in speculating beyond that. By that, I mean that it won't get us anywhere.
