alpi69
I found a minor issue in the menu/view controls.
When you select the Edge Monitor (controlling focus) with the LCD attached (via the dedicated button) and then take the LCD off to work with the EVF alone then the area that is occupied by the Edge Monitor is not showing anything in the EVF! In this area are the most important value-prompts: F-stop, ISO, shutter speed and audio. They all disappear in the EVF. You need to go to the menu to turn the Edge Monitor off although you have no LCD attached! You also can´t press the Edge Monitor button anymore, unless you have it programmed on the body itself also.
They should program it so either you have the Edge Monitor in the LCD (and Waveform etc) or the EVF should simply stay as is, regardless of the settings on the LCD.
