Follow Focus ring gears that work with lumix 20mm pancake lens?
bronxjragon
I have a d|focus with my GH1 and the D|gear that I use does work, but barely. Does anyone know any other ff gear rings that work well with the pancake lens?
no i have both these rings and the 20mm no way theyll work. the lens sits too close to the cam. i m interested in others solutions for this too.
ugh, i just bought the indi snap gears. at least it'll work with my 50mm canon via adapter and the 14-140 kit lens
D|Focus + small Zip tie gear on 20mm Lumix
GH2 on a FieldRunner with D|Focus, and a small zip gear on 20mm lumix, you have to reverse the gearbox on the D\Focus
Link: http://yfrog.com/h4pn7axj
http://yfrog.com/hs4yrenj
I think a follow focus on the 20 1.7 does not make much sense anyway.
When focusing on subject 1 and then on subject 2 and then back to subject 1 using follow focus marking white disk - you will see the subject 1 is not in focus .
This is a big problem with dedicated MFT lens. You should use the focus guide on GH2 lcd instead.
14-140 lens - the same story.
Nikon / Canon / Zeiss with manual focus / aperture ring will work well.
