keylight
Lumix lenses focus by wire - there is no hard connection between the focus ring and the elements inside the lens. So what's the best solution for follow focus setups? I've done a lot of research and from what I can see, there are really only two types (well, there's a third, but I doubt it would work). So I'd REALLY like your input if you're using a follow focus with Lumix lenses. I'm going to get something soon and I'm not sure which is the best way to go.
Here's what I've found:
The first type is Friction Follow Focus, but frankly I'm a bit dubious about it. Any thoughts? These are what I found.
Jag35 ($199):
Ikan F3 ($180)
Shape ($552)
Triad (about $880)
indiSystem ($99)
Then there is the traditional geared follow focus that needs a corresponding gear ring with teeth. Everyone here knows about these.
Like this one:
Ikan ($400)
that comes with these:
But the problem is the belt. Can use it on a Lumix lens because you need 360+ degrees to focus.
EzFoto ($13)
After searching for a long time, I finally found this. I have no idea how well it works.
Cinevate ($50)
Or a 3-Pack ($98)
So.... What are your thoughts? What do you use for follow focus on fly by wire lenses?
Bonus: Here's that 3rd approach. I kid you not! ($50)
Jag35 ($199):
Ikan F3 ($180)
Shape ($552)
Triad (about $880)
indiSystem ($99)
Like this one:
Ikan ($400)
EzFoto ($13)
Cinevate ($50)
Or a 3-Pack ($98)
