Focus and Zoom presets..!
Ates
Hi,
Can anyone help me how to set and recall these presets? Because I read the manual but i couldn't manage to do that.
What i did is:
- I set camera to focus mode
- Arranged the focus
- Changed state to "ON" and it went back to "set" again
Was that wrong? If it was not i couldn't restore it..!
I think I might not understand, but I might.
You slide it to SET at the focus that you want, then you're free to move the focus. When you slide it ON, it will recall the focal length you just set.
yeah that's the way super quick rack focus's, also good for 35mm adaptor settings,
focus on your glass and make sure your zoomed into the glass properly,
select it to on you know youve got the right settings ;)
Russ
Just a note Ates that you should check/reset the presets every time you mount up the Brevis to your XH-A1. Engage peaking and focus assist when you do it as setting back focus is the single most critical thing you can do with an adapter.
