GH3 Focal length ? For video/short film
Just starting out and preparing to start on first short narrative film. I have amassed a collection of primes covering the range from 12mm up to 85mm.
My question is will i need anything longer than 85...like maybe a 100mm or will i be all set with that range?
Also, i do own 2 kit zooms (14-45 and 45-150) but i do not really like the look of them enough to use in short and they are both slow as well.
Any insight would be helpful. Film will be narrative suspense.
I have the 14-45 and it is very sharp, but as you say slow, so I rent the sigma 18-35 with speedbooster when I need the speed. It may be good for establishing shots. I also have the 20mm and 42.5mm both f/1.7 and a Canon FD 50mm f/1.4 that I rarely use.
The only reason I can think you'll need something longer than 85 is for some reason you need extreme distance from your subject or an extreme close-up.
My question is will i need anything longer than 85...like maybe a 100mm or will i be all set with that range?.
Shoot within your means!
Have you scheduled pre-production and gone over the shot list at the needed location?
Is there then a need for a lens greater than 85mm?
Do you have budget set aside for more lenses beyond 85mm if needed?
85mm should be enough (assuming you are shooting on the sensor natively with no Speedbooster). For suspense it is not uncommon to shoot longer focal length which does 2 things:
1) Gives tighter framing to make the character feel trapped or confined.
2) Gives a compressed perspective so backgrounds appear closer than they actually are. Again, this gives a feeling of claustrophobia or being fully surrounded to the image.
