Hi, When I connect FS700 to PC via USB, FMU128 unit is not detected by Windows. Only SD card is detected. Is it supposed to be this way? When I connect FMU128 to PC directly, it is detected normally.
Ages since I've used an FMU128. From memory that's the way I always used it, connected directly via its mini USB. I do seem to recall though that you could connect via the camera to the FMU. From memory, you had to select "Mass Storage" when connected. Plus, I might be wrong here but I think you had to use Sony's "Content Management Utility" software for this. Also maybe worth checking out check this page to make sure your USB mode settings are as suggested. This page was updated last month.
