GH2 FIX to stop the VIEWFINDER / LCD from Changing
Ralph B
We all know how the Viewfinder /LCD panel changes color/gamma when going from standby into record.
Well, today I stumbled upon a way to stop that from happening. Go to page 4 of the Custom menu and set CONSTANT PREVIEW to OFF.
That's it.
Now the viewfinder will appear the same in standby as it is in recording.
Sorry, false alarm. However, setting CONSTANT PREVIEW to ON does affect how the viewfinder / LCD behaves when you shoot with shutter speeds faster than 1/1000 sec. Basically, it's not good. If set to ON, the viewfinder doesn't respond to shutter speeds faster than 1/1000 sec when in standby. When you hit record, suddenly the viewfinder jumps to the real exposure.
I was shooting in bright daylight at 1/2000 sec and wondering why the viewfinder was acting so bizarre.
When CONSTANT PREVIEW is OFF, this doesn't happen - in standby, the viewfinder does respond to shutter speeds faster than 1/1000. So, CONSTANT PREVIEW = OFF is the correct setting.
The best thing you can do to avoid shift is to lower the lcds contrast, raise the brightness all the way, and switch the backlight mode to 1.
