killmaster
This is my first digital shoot ever. So I'm stumbling around through this process and realizing how much new stuff there is to know.
I am shooting an instructional DVD on engraving. This last weekend I did a test. I shot the person who is going to be doing the presentation in his engraving studio. I took a light with me but is looked so good without a light and setting the ISO to 800, that I decided to shoot without adding any light to the overhead fluorescents. The image looked really nice on the LCD and the original footage looks really clean. On closer inspection, the image is super grainy and you can clearly see the noise swimming around everywhere. His plaid shirt is moireing like crazy too. There is one shot where I can see a block of wood with narrow carved lines and not only is it moireing, but the lines are broken up into random prismatic colors. Also, I had to crack up the volume to max setting to get a good level. Viewing the ProRes transcoding was yet another surprise.
Here's the setup:
equipment:
T2i
EF-S 18-55 f/3.5-5.6 IS lens (I have an EF 50 f/1.8 II lens but didn't use it, maybe should have)
Transcend class 6 card
Art Professional Mic Tube Preamp
balanced XLR cables
AKG Lavaliere Mic pinned on his shirt
Olympus LS-11 recorder set at PCM 48KHZ 24bit (going to line-in from the pramp)
Huge bank of fluorescent lights overhead and a few stray incandescent lights (took Lowell RIFA light but didn't set it up)
settings:
shooting 1080p30
f/3.5 to f/6.3 at all times
shutter 30
ISO 800
preamp input and output are maxed, needed phantom power for my mic too...
LS-11 at 10 (max) - voice peaking around -6db
Original footage looks just barely acceptable except for the graininess. Overall the image is really soft except in the narrow range where the focus is. Super shallow depth of field I guess.
If I could edit this and export the original as is, it wouldn't be too bad BUT when I run it through my pipeline, it degrades to such a point that it is completely unusable.
Here's the workflow:
1) shot video with above settings, looks ok but sound, though clean, seems low volume
2) transcode to ProRes LT (did a test and there was little difference between this and HQ or regular)
3) edit and send to Compressor and burn a high quality DVD mpeg-2 file which looks completely horrible and has lowish sound
4) export using Compressor to H.264 at 10.3 Mbps
5) DVD Studio Pro refuses the file. Ok, I get it now. I would need to burn a Blu-Ray disc in order to get full 1080p resolution back out.
At this point I'm stuck. Not sure how to eek the most original quality from the image. I can't edit the original .mov files in Final Cut Pro. So here are my final questions:
1) I assume more light will help. (assuming is a kind of question)
2) should I be shooting at ISO less than 800?
3) should I use a sharper lens?
4) My camera shut off twice (not at the 4GB boundary either). The meter told me on several occasions that the camera was struggling to keep up writing data. Do I need a class 10 card instead?
5) Must I transcode to ProRes or can I use ProRres Proxy and substitute with the original files when I export?
6) If I want this to be a hi-def project, how am I supposed to burn it at 1080p? What is the highest resolution I can burn a standard DVD at? What is your worklow (I'm on a mac with Final Cut Studio)
thanks for any hints here...
Here's the setup:
equipment:
T2i
balanced XLR cables
settings:
shooting 1080p30
shutter 30
ISO 800
