LanceOregon
Haven't done DR testing yet. Will do next week.
And you have simply got to write a book for this fantastic little camcorder too!
Felipe?? I think that the wider lens will be more than enough!!!
Let me address the issues raised here:
(1) LCD: The LCD is about 1.1 mega pixel and is very sharp compared to the HMC-40.
(2) Fixed Lens Hood: This is going to be a trade off of the AC90 vs the HMC40. You would have to reach down into the hood to turn a polarizing filter. As for putting on a wide angle OR telephoto adapter; there was a lot of room to be able to fit one inside the hood. I don't see any problem with adapters not being able to fit inside the hood.
(3) No wave form monitor: Crud! The camera does have a histogram; which is OK, but not as good as a waveform monitor IMHO. I think of all sorts of things to check after I left the building and I'm on the train going home... The HMC40 does have a spot setting with an IRE reading; does the AC90 offer that? I have no idea, but I wish I had asked. IF it has the same IRE reading as the HMC40, that might be a workaround for getting more exact readings.
(4) Different battery: For us, the battery is not the same as the HMC40, but for others it matches the 170. Some win here some lose here.
While I'm at it, the next video showing the rapid auto-focus is uploaded:
Link: https://vimeo.com/49952262
There is going to be some trade-off in selecting an AC90 vs the HMC40. Each has it's strong points and neither model has all the advantages. If I had to start over and chose between the two models, the fantastic image stabilization system, the better viewfinder, the build-in XLR, and the wider angle on the zoom range, would make me pick the AC90 over the HMC40.
Bob Diaz
The battery is like is the 170 B&H is wrong, that happens at their website frequentlyLittle confused on the batteries. Jan said this uses the same battery as the 170 (CGA-D54). B&H listing shows battery as VW-VBG6. From photos batteries look the same but are they in fact interchangeable? Sitting on a bunch of D54 for my DVX's.
Hi ChrisHi Felipe
It seems they have gone back to the standard CGA series battery which is great news cos they don't need a decoding chip and you can use the same battery essentially as either the HPX170 or even DVX100 batteries. Batteries like the CGA-D54 are also easy to get from quite a few suppliers and you can also get the D54 with a dTAP connection too which is great if you use a video light and need to power from the camera battery!
BTW : the wide angle of the lens is actually 29.5mm (35mm equivalent) so that's a fair bit wider than your current HMC40 at full wide ... nice for weddings too..with the HMC's I have to often move back a bit as it's only a 40.5mm at full wide.
Chris
Chris
Bob Diaz
The B & H website is incorrect. It is the same battery as that for the DVX and the HPX170s or the HVX200s.
You can program the Histogram to the User buttons and it works very much the same way as a WFM, but without the markers. But I think it is still a viable tool.
Why not just a firmware update since the camera hasn't been released yet. ( That is all it takes a firmware update ).
Histogram summarizes values for the entire image: usually luminance values 0-256 horizontally and the relative quantities of pixels with each value vertically. Waveform monitor shows you all of IRE concentrations for each vertical image segment. Completely different pieces of information.
Bob and Barry, Thank you for extra time and effort you are putting in to answer forum questions. Bob, you mention AC90 LCD is sharper than HMC40, but what could you say about the EVF--is it any bigger than tiny one on HMC40? Dennis
Thank you Bob Not too big but very interestingOne last video to share, here's a walk about the show floor at DV Expo.
Bob Diaz
