First lighting kit?
junct
Hey there,
Let me say that I've only just started researching lighting. I've been using a few work lights and natural lighting for my stuff so far, but I want to invest in some actual (albeit low budget) lighting gear. Any tips?
The biggest issue for me is living in New Zealand where everything is expensive, and cheap things overseas are expensive to ship here! I'd like to spend under $400USD (shipping is typically $50-$100). I mostly shoot indoor narrative work.
Would a kit like this work? http://www.trademe.co.nz/electronic...ssories/lighting-studio/auction-726497850.htm I tried to search the brand, but I guess it's a no-brand chinese type thing. I realise there is probably a bit more than I need, but the price is quite good (or is that a warning sign?)? I realise this is mroe of a photography kit, and the umbrellas aren't that useful (I'd sell them).
Thanks for any advice!
Flags, diffusors, mirrors, gels, cookies - That's really all you need to shape light on the "negative side". And maybe pick up a used 2kw Blondie and an Arri 650?
Really nowadays though cameras are so sensitive to light you can produce some really good images from modifying existing lights alone. Trying to have at it from the "positive side" on a budget like that will only cause frustration.
You don't want that kit, it's for photography and most of the useable items are cheap as chips anyway. Reflectors are a good first purchase and even the cheaper ones on ebay do the job. Reflectors can be used in daylight for fill which gives you more control outside and used creatively indoors to either soften a hard light or stand in for a light you haven't got. One reflector can let you do three point lighting with two lights. More than any other early purchase it gets you thinking creatively.
The three technologies you could look at would be fluoro biax (a bit cheaper than kino clones), tungsten and CFL. There are plenty of super cheap CFL kits on ebay that are well within your price range. I would say they are the most affordable options. Here is an example:
http://www.ebay.com.au/itm/PHOTOGRA...tDomain_15&hash=item35d624a6d0#ht_2429wt_1153
This is just an example, I don't endorse this seller. My preferred seller must have forgotten to pay their ebay fees because their store is empty at the moment. But they all pretty much sell the same crap, just put 'lighting kit' into ebay and hundreds will pop up. They are not particularly great and targeted more at photography but they will work for video. The advantages are you could probably get two kits for your money, they are cool to run and even with many of them, the load will not add up to a blown fuse/tripped breaker (unless there is an electrical fault). They are also frequently bundled with a green screen muslin if that interests you. You could probably get 4-5 lights and a large greenscreen with hanging frame for your money with enough left over to grab takeaway.
If you decide to go with these get ones that use single large CFLs with high wattage value. There are seemingly cheaper multi-bulb heads but they are more trouble than its worth and dramatically increase set up/pack down time. The stands are really flimsy, you'll want to think about getting some cheap sandbags to steady them. In fact think of the whole kit as disposable. With the included softbox you get a big source of diffuse light. Only use CFL with this softbox, with hot lights like tungsten or halogens it will catch fire.
Shadows will be soft rather than defined and wrap around the subject. They are pretty much all daylight balanced which means they don't play well with tungsten lighting. I bought a set of these ages ago to light a greenscreen. In terms of usefulness I rate them above worklights and below everything else.
The next option would be tungsten fresnels which I think would be the more valuable route educationally due to features. Tungsten fresnel will get you the ability to focus between spot and flood, come with barn doors to help shape the light and you will often get a carry bag and some cheap gels thrown in if you buy them as a kit. You can cover pretty much all basic lighting with those features and included extras. Coming from worklights you will love the extra control. Here is an example:
http://www.ebay.com.au/itm/As-Arri-...ltDomain_0&hash=item20e0996780#ht_7884wt_1780
This seller I do recommend and have had only good experiences with. Most my cheap lights come from them and all are going strong. Most kits come with free courier shipping too and arrive in a few days. The stands that come with these are actually pretty good for the price, still not professional but strong enough if you take care. Much more durable than the ones that come with the CFLs.
Tungsten is a point source which will produce well defined shadows. The light can be diffused with an included gel pegged to the barn doors or bounced off a reflector for a larger source and softer light. The light quality is the best of all your options but the drawback is high power draw and they get very hot (like your worklights but better ventilated). 2000W of these lights produce more heat than my gas heater and will sometimes trip the breaker when my fridge cycles on a 16A circuit. These will play well with your existing worklights which are aso tungsten balanced.
The third option which is a little more than your budget is biax fluoros. They are a bit cheaper than kino knockoffs and have much nicer light than the CFLs. They provide a big soft light source. I have the kit I link below. I'm very happy with it and plan to get another. I sometimes use it for a key/fill light, other times just bounce off the back wall to raise the ambient light level for my light hungry camera. It can be ordered with daylight or tungsten balance tubes. I got tungsten balance to play nice with my fresnels. This particular model comes with barn doors (not all do) to provide some shaping and can has two power switches so I can use half or all of the tubes.
http://www.ebay.com.au/itm/8-Cool-S...ltDomain_0&hash=item1c3fd8ad41#ht_2843wt_1052
It is worth saving up for the kit for the extras you don't get if you buy them individually.
That should be enough info to get you started. After playing around with any of these options you'll have a better idea of what you want. A single small Arri light will blow your entire budget so bear in mind that all these suggestions are cheap gear. The build quality of the knockoff fresnels is pretty solid, the biax units are okay and the CFL very flimsy indeed. I also recommend you get the lights tested by an electrician when you get them. The wiring in these chinese units is not always first rate but is easily detected and repaired by a Sparky who will probably do it for beer. If not you still are only looking around $10 a unit. It is a small price to pay for safety. It is rare but in 10 items tested I did have one loose termination and several members have reported far more dangerous issues.
if it's cheap enough you can afford it from your weekly paycheck, it's crap.
you'll have to actually save up some money and invest if you want a decent kit.
but that shouldn't stop you from learning how to light. it should just stop you from buying "kits" that are trying to take your money. Go down to the hardware store and buy some clamp lights. Get some work lights. Go buy some sockets and make your own 300watt tungsten lights. It'll be a good learning experience and you'll have a couple lights you can mess around with and start learning.
Thanks EGS, that's a really really helpful starting point! To me, it feels that the Fennels are the best option for me at this stage. However, a couple of questions:
Do you personally find the 300w bright enough if it were your *brightest* light?
How much control do you have over how harsh/bright the light is using gels and whatnot to diffuse the light? I note that the lights aren't dimmable.
How do they play with greenscreens? Does the type of light even matter here if you can light it evenly? I've not used one before, but that was to be my next investment.
How tricky is it get gel them to a daylight balance (I like natural lighting as a source)?
Good tip on the electrician thing - I was concerned about the knock off safety thing, but never thought about getting them checked! Silly.
Also thanks imaj, I'm still looking at those sorts of kits as well. See that mentioned a bit.
Sonofaresiii: I'm a student. My weekly paycheck covers my rent and expenses with enough for a couple of pints left over - so saving up much more than I've budgeted isn't a hugely realistic option. I have done some experimenting with clamp and work lights, and have done ok with them, but I want to try something which I can control a little better. As for making my own - that is an option, though I am terrible with any sort of diy work, and my only work space is my small bedroom.
It depends on the sensitivity of your camera but the short answer is not really. It's not even so much an issue of brightness, it's coverage. The bigger the light, the bigger circle it throws on the wall. For a small room in a house you don't need bigger than 650W (unless you are bouncing in the window from outside), for a larger room maybe 1000W and for a small bar or shop in a wide shot you'd be wanting at least 2000W for your key. But 300W will get you started, you can at least key against the 150W. Also you won't get a great deal of bounce off a wall or the ceiling with the smaller lights. You can get an idea of what you will get from your worklights, it's a similar output per watt. The coverage is smaller though even on flood, the fresnel lens focusses the light and there is less spill.
You will eventually want at least a 650W for indoors but the three light kits I linked will at least get you started. I want a 1000W but and it's not worth getting until I move into a more modern house because my current circuit can't handle the power draw. When I do eventually get a 1000W and 2000W I will be getting genuine Arris. I've read some people have had the lenses crack on the 2000W due to cheaper materials but I've never had any issues with the 650W. If you can't stretch for a kit that includes a 650W I'd just go for one that gives you three lights. You'll get the stands and starter gels and then you can consider buying an individual light or two as the money dribbles in. They have a 650/300/150 kit that if you combined over time with a 150/150/150 then you'd have a pretty good kit that a household circuit should be able to power. That should be enough to take care of a fairly professional talent and background lighting in a small room. After that you might want to get the fluoro biax kit with tungsten balance because power availability (I'm guessing in NZ you'll have 240V with 16A fuses/breakers - check in your fuse box) and heat. That's the core of my set up and there's a fair bit of flexibility in it.
The included diffusion gel takes the edge off and makes the source bigger. It is still higher contrast than the biax units I have, the light doesn't wrap around as much. Shadow lines are still defined but with a softer edge. I use it more often than I don't and there is some light loss involved. This can be good in a small room as 650W is really bright at 2-3m. Also I find making it a touch softer and a larger source makes it more comfortable to be in front of camera. With lower value lights you have to get in pretty close so they're really in your face and bear in mind smaller lights are still twice as least twice as bright as most domestic ceiling lights.
As for dimmers, you can request them from that seller (photolight) for about $25 a unit. Or you can get inline dimmers at the hardware store. Or you can do what I do and physically move the light closer and further away. Lights fall off over distance. Rule of thumb if you move a light back half again (2m -> 3m) it will slightly more than halve the light. Move it closer in a similar fashion (eg 1.5m -> 1m) it will slightly more than double it. Moving small lights further away can also help in controlling the point source lighting problem of multiple shadows.
You can use tungsten to light a green screen but daylight is better because it has less red/orange spectrum. With green screen lighting you want only green to reflect off it with no spill onto the subject. However, a good thing about this is you are removing everything lighting the greenscreen so the colour balance doesn't need to match the lighting on the talent. My first lighting kit was a 3-light CFL kit. I was so disappointed with it I bought tungsten lights immediately after my first use of it. However it is perfect for lighting green screen so that's what I use it for now. The green spike that ruins skin tones is actually an advantage here. And the big soft boxes are the key to lighting it evenly.
You simply peg the blue gel to the barn doors and voila. It should be noted that the included gels are only to get you started, they are not Lee or Rosco. They are blue, orange, yellow and diffusion; not CTB, CTO, Straw and Frost. But they get you close enough to learn the theory. With professional gels you don't just get a CTB but they come in specific values, 1/8, 1/4, 1/2, full, double. Not all daylight is created equal and it changes throughout the day. The problem with gelling tungsten to daylight is that it isn't very efficient. Tungsten doesn't have much blue so the output is considerably reduced (2-2.5 stops from memory, but it's a lot). Whereas going from daylight to tungsten you only lose half a stop I think. With smaller lights if you go tungsten balance you really have to go all in.
I would recommend maybe trying to avoid situations where daylight fights your tungstens for the time being. If you keep the two separate a white balance is all you need to keep the footage matching. Secondly learning to light in a controlled environment reduces the variables and will help you to nail the basics before you encounter the issues of the real world. It will force you to make deliberate choices dictated by your inner artist instead of best compromises dictated by the environment. Thirdly these lights are not powerful enough to compete with the sun. Even a 650W isn't really enough. Fourthly, interiors with windows need to either let the windows blow or require ND gel over the entire window. You can't afford that.
I figured as much. That's why I have tailored the advice to your situation. The recommendations I have made are intended to give you the best possible set of (substandard) gear which will be relatively durable and give you the opportunity to develop skills that will transfer to professional gear. I think tungsten is your best bet in this respect, provides the best light, is affordable, reliable and the only real compromise at the cheaper end of the spectrum is fit and finish.
After having this kit for a while the heat will eventually have you questioning priorities. As you say, daylight balance may become the most important thing for you. But hopefully you'll have the dosh to have choices by then. In the future for interviews, corporate, sit down documentary you might want to consider something rugged and easily portable like a Lowel kit. If heat/power/efficiency has become a problem the various fluorescent light types can be a good solution, if expensive. Fuoro tubes can be found in tungsten balance too so it will be easy to transition to and with spare tubes of both varieties you can have the best of both worlds. Portability and battery powered LEDs will be a lot better by then and may be an option. Although even the top level ones are still aren't there yet and the cheapies are still more expensive for one than an entire tungsten kit.
EGS, once again, that's an amazingly helpful answer and has close to convinced me. I'll give it a couple of days of research to get some other thoughts, but at the moment it seems like a suitable option for me. Although, is it worth looking at one of the other, more expensive kits like - http://www.ebay.com.au/itm/As-ARRI-...H_DefaultDomain_0&hash=item20e098ade5&_uhb=1? I can think of a few things I'm developing at the moment where I would need the strength of the 1000w (though those won't be in production for 6 months or so). Or is it more desirable to learn to use the lower strength lights first? I take they are also inconvenient to not have in ones kit?
If you can stretch to that kit, you definitely should. The suggested 300/300/150 was a compromise to fit your budget. Combine the 1000/650/300 or 650/300/150 with the 150/150/150 kit or the 300/300/150 kit at a later date you'll have a very useful kit in 6 months.
This seller used to have a premium brand 'Jie Tu' which were the ones I bought and where about $20-30 more per light than the As Arri. At the time the As Arri cable was noticeably inferior even in the ebay photos. However when I bought my biax units I received a couple of bonus As Arris 650W, either in error or because they had run out of the particular kit I purchased and upgraded it to the bigger one (didn't ask, didn't tell - maybe they saw I was a good customer) and they were identical to the Jie Tu ones now. So I'm guessing they retired the brand and made the standard one better. I haven't tried the 1000W as I said. I did intend to take the risk on one myself once I moved house but I'm probably going to buy genuine Arris instead now because they're only about twice as much and I can afford it now.
With the big lights you'll be able to get further away but they are correspondingly hotter. Of course it's winter so maybe that's a good thing. You definitely won't need a heater in any room you're using these. In summer if you don't have aircon it might be a bit much. My aircon stopped working this summer so I couldn't do anything for 3 months when the landlord wouldn't fix it. Once you've got your key light sorted my favourite light is the little 150W. So many uses. If you get either the 1000/650/300 or the 650/300/150 kit I'd suggest saving up for the 150/150/150 after that. Don't neglect the small ones, great for hairlights and background lighting and not so much heat. Once you've got two kits you'll have six stands and plenty of gels so after that buying individual lights may be more cost effective.
If I was doing it over, personally I'd get the 650/300/150 first. Then supplement it with the 150/150/150 kit. Then I'd either get the 1000W separately or if I had the funds get it in the biax kit (the one with two 4 bank biax and the 1000W fresnel in the big aluminium case). But that's me, your needs sound different. I currently do most my work in a 4.5x3.5m room so 1000W is too much. If I don't put the camera in the hall I can't get further back than a medium shot with the subject 3 feet from the wall (a bigger 'studio' space was a prime factor in the design of the house I'm building). If you budget and plan the next 12 months of spending now, knowing what you plan to achieve over the next 6 months, the correct first purchase should be obvious to you.
Last advice: my theory, in contrast to the 'buy it once, cry once' mantra is that you can't do much with one professional light. After you have the functionality of half a dozen lights, then it becomes smart to buy name brand quality. In the meantime you've learnt how to use them with your cheap set up. I'd say these probably aren't tough enough for rentals but they are plenty tough for an owner-operator who looks after them. The stands are plenty strong enough for the studio where you can control peoples movement in the space. If someone was to walk into them, knock them over and fall on them I expect they would break but that is true of name brand aluminium stands as well. Aluminium stands are not even remotely as tough and durable as steel c-stands. Sandbags will be a good investment. And I haven't needed to test it myself but I'm told Arri spares fit these perfectly.
Now go and make the next lord of the rings. Or better yet the next eagle vs shark! Love nz cinema. Funny accents withstanding :tongue:
Tip 1: Buying used is a great way to extend your buying power.
Tip 2: Rather than purchasing a new kit made up of lesser quality components which you will end up replacing a short time later, purchase higher quality used lights which will last you a lifetime. Great deals are out there if you search places like eBay and the like. Start with a single light, stand, stinger, light modifiers.
I have over 70 lights in my kit now, and the majority of them were purchased used, a single light at a time.
I'd suggest starting with 1x Kino 2' 4-bank fixture, 1x 2000w blondie for punch, 1x 650w Fresnel for control, backlights etc. and see how much you have left over afterwards. If you've got enough left over for some small kickers (150w/300w fresnels) that'd be great. But I feel like that basic kit would probably offer the most versatility from the get-go. Definitely use a bit of the money for a 3x3 or 4x4 frame for diff, and some decent stands.
$400?! Whoops. I thought it was $4000... I must have made a wrong turn somewhere, this is the wrong thread.
$400 might get you two 'okay-ish' used tungsten lights (most likely basic open-face units), but that's about it. It'd be pushing the $400 limit a bit, but my suggestion would be to get a 2k fresnel and a couple of 5-in-1 reflectors - then look into 'reverse key lighting'. You can get some great results from that, and having the added output of the 2k will give a bit more flexibility.
Then as you scramble some extra funds together, add first a 650w frensel, and then a 300w/150w as kicker.
Thank you for everything, your advice has been pretty invaluable, I'll keep researching now. Didn't care that much for LOTR (or much of PJ's work over the last 10 or so years) but I suppose it wouldn't be a bad accomplishment! As for Eagle Vs. Shark, I struggled with it, but Taika Waititi's new film looks like it's going to be pretty great.
I agree buying used is a good option, and I will do some research on buying lights one at a time. However, spending much more than my budget isn't really that feasible (as outlined abover) even if spread over time. I simply don't have the funds to do that - I'd rather make 3 films in a year with bottom of the line lights and learn some basic lighting theory than make none because I only have one good light.
I should also note, I don;t really have ambitions of being a DoP. This solution is something to cover me for my own small projects and become more experienced with the camera side of filmmaking (and at this stage, I have mainly served as my own DoP, but I don't believe that's where my talents lie). This is to serve for small, personal projects - my future, budgeted projects with much higher ambitions will be using people of much higher DoP (and other areas) of experience than myself.
I do, for the most part agree with the buy it once philosophy, it just doesn't quite suit my needs at this time. But thanks for your input :)
I wish my budget was $4000 :)
Thanks for the tip! I did just order a 5-in-1 reflector. I'll take your thoughts into account. Though I think I'll still end up going with the 650/350/150 kit at this stage. My next few shoots are all pretty intimate, and in small spaces, so they may prove more useful. I do have a shoot coming up at the end of the year, where I think I'll be needing some more powerful kit, but I'll cross the bridge when I get there!
Take that advice about 2nd hand with a pinch of salt. By all means have a look. If you do find a good source let me know. But I already tried and failed, that's why I went to the length I did to help you out. Hopefully with practical advice. I'm all ears if anyone on this side of the pacific has a different experience.
It's frowned upon around here to say 'it's harder outside the US' which has good reasoning behind it (discussions can get heated) but advice frequently assumes that it isn't and so doesn't always carry the same weight to us. I tried second hand but there isn't really anywhere here to find it locally outside of personal contacts. In almost three years of looking I've sourced two big items from Australian sellers, both amateurs that got in over their heads and gave up the hobby. I certainly know I would be reluctant to sell anything I've got my hands on even if it's not getting use because it will be a ***** to find again. Local corporate video people I've spoken to will use gear until it is beyond repair. There's a thriving 2nd hand market for photography but seems not enough video people to support the same. I'm the odd one out at local camera fairs. That said the situation could be a little better in NZ, given hollywood invests a bit of money there and government seems to invest in local content. So do check it out.
Also very few second hand items from the US even list on local ebay and if you contact sellers through the US ebay site they generally refuse to ship due to weight. Even if they agree the shipping is invariably more than the items, often more than new prices. I have found one ebay seller that occasionally sells bulk lots of broken gear for cheap but its mostly from theatre, domestic freight is still expensive and try finding parts. It might be easier for a professional with a pro budget and the ability to write off against tax to bring in bulk consignments of retired gear but not the hobbyist.
As for new, most local distributors seem to be some guy in his bedroom collecting dozens of exclusive distribution rights with no actual knowledge of the product, quotes taking a week or more and prices 3-4 times what you'll pay online. And distributors in other countries aren't allowed to deal with you. Ebay, B&H and filmtools are ultimately the easiest way to go. At least that's been my experience. If someone on the east coast has a better story to tell I'd like, no love to hear it.
Hmm, that was all a bit whingey, cheer up Egg! :violin:
Nah, you're right - any filmmaking equipment is ridiculously hard to come by in New Zealand. What you do find is low end stuff (again, usually aimed at photography) at ridiculously inflated prices. The second hand market is tiny, and I haven't really found anything from lights to tripods a feasible local option. The only things I have purchased locally are one vintage lens, a lens cleaning cloth and as of today a 5-in-1 reflector. That's it. Even with the huge shipping costs at times, importing is almost without fail cheaper, and I'll only go local if the item itself is cheap enough or if I need it quickly.
I would be looking at overseas 2nd hand shopping sites for any lights (haven't looked yet) because of this, though as per your suggestion, this may be a futile search!
Back in March I followed Egg Born Son's advice and bought the fresnel kit from ebay (150+300+650+1000+dimmers+stands). Pretty nice. The light from these tungsten bulbs is A LOT nicer than what my cheap CFL ebay lamps throw out. And these get to be sharp if I need them to, which is nice. In terms of light output, the 300W is similar to my old 150W CFL, but with a lot more control over how the light is distributed. The only downside with the fresnels is that they get really hot and adjusting them is not so easy (thick gloves needed).
Glad it's working out for you. That's why I champion them for broke filmmakers who aren't in a position to follow the conventional wisdom. If they are crap they are at the top end of the pile. I did a lot of research before I decided on them and can testify to the fact I've had no issues up to 650W in 2 years of hobbyist use. Not one failure or damage in that time (dropped a couple but generally babied) and to give you an idea of how much they've been used, I've replaced around half the bulbs in that time (no early failures).
The specific deficiencies by my assessment: Most have been fine but they are occasionally wired badly or even dangerously (get it tested by a sparky) and the cord isn't anchored by the sheath at either end so the wiring takes the full weight, don't pull on the cord (bad practice anyway) or better yet while you're at the sparky get it modified; the yoke is tough but not as durable as a genuine unit; and from forum posts the lens is made of inferior materials and prone to cracking in the 2000W units (making me cautious about the 1000W model - I don't have one so can't confirm); and the flood-spot control is not as smooth but that is a minor inconvenience. Otherwise I can't see anything wrong with them other than the fit and finish being a bit slapdash.
What are your experiences with the 1000w (given that EGS has expressed some concern over the durability of the lenses)? And, I know this is a pretty impossible question with probably too many variables to answer, buuut, do you find the 150w or the 1000w more useful? I am considering either the 150+350+650 package or the 350+650+1000 as they are similarly priced (but already extending my budget). I guess in what sort of applications is the 300 too strong, and the 650 not strong enough?
