Barry_Green
Moderator
Alan Roberts makes an awesome observation over on the dvdoctor thread -- that if you're viewing it on a computer, it's going to obviously and always involve a frame-rate conversion -- and frame rate conversions introduce judder. A television or proper video monitor will change its scan rate to match the frequency of the incoming signal (either 24Hz, or 50Hz, or 60Hz) but a computer monitor will always run at whatever refresh rate it's set to run at -- typically 60Hz or 72Hz. So when you watch video on a computer screen, there's usually (if not always) going to be a scan rate conversion happening -- and that will introduce juddering and unnatural rhythms into the video. And one reason that 25p folks might be noticing this more than our 24P brethren, is that 24p easily goes into 72Hz (no frame rate conversion necessary) and 24p on 60Hz looks just like what we're used to always seeing anyway. Whereas 25p on 60Hz or 72Hz doesn't work, and results in the computer having to synthesize an unnatural pulldown sequence.
I reiterate -- the absolutely only way to test for whether there is an issue with the camera or not, is to watch the footage from the playback of the camera, on an appropriate VIDEO monitor. And play back from the camera, not from a PS3, because also in the dvdoctor thread, there is a statement made that the PS3 does an internal standards conversion from 25p/50hz to 60Hz. So plug the camera into a monitor and look at it there. If it looks good there, then the footage is good. If you have computer issues that are causing jerkiness and strobing and whatnot, well, those are, by definition, computer issues.
