Looks great.... what lenses did you use? Also what did you use to keep the handheld stuff stable?
Great editing and storytelling. Visually beautiful - But what gets me the most is the constant shaking from being handheld. Where you using a monopod or shoulder brace at all for this shoot? I'm guessing that the prime lenses don't use image stabilization.
The bridesmaids walking down the aisle in the first chapter was slo-mo. What film rate did you use? Did you shoot at 60p for the intent of slowing it down or was it tried differently in post? Also what lens was used for this - it had a nice warm glow to it, but the cutaways where a little washed out.
Hey Gary,
Great work and good to see you over here. You might have just convinced me to get a GH1 as the wedding video I've seen shot with this camera up until this point hasn't been in the most capable hands. The small amount of preceremony I've seen shows that while it's not a 5D, the Panny is no slouch in the image department. It's certainly an upgrade from any HDV camera out there for under $5K.
Thanks for sharing and hope you're doing well!
Chris W
Hey Psynema - Finished watching the other segments of your wedding film and enjoyed it. Loved the use of the speeches thru out the edit. (Again wish I had good speeches to work with) How did you capture the speeches? It seems like you have a light stand in front of the DJ's speaker with an audio recorder mounted to it. If so can you go into detail about that - (placement, levels, monitoring....)
I have a Zoom H2 that I've used in the past with varying results. Sometimes the DJ can patch out with RCA, others can't. Decent results with this method but can't always get good levels without constantly checking the H2. Other time just hiding the H2 somewhere in the reception hall often with not so good results.
Have you shot any recent events with the 2 cam GH1 setup? What would you change about shooting the next event? Are you adding more gear/lenses?
Sorry for all the questions - Just looking to be inspired for the upcoming wedding season both shooting and editing.
Thanks in advance - Mike
