Firewire repeaters
smelni
If you want to use firewire to connect the hvx to a laptop it would be great to have a very long length of cable. I have been trying to find a repeater solution to help with this but have not been able to. The camera port is 4 pin unpowered and all the repeaters seem to be 6 pin powered - they have to be powered to make the repeater work i beleive.
So any ideas how to entend a wire with repeaters to give maximum range with the hvx?
That probably wont work because the power line is in the 6 pin and needs to hit the repeater to give it power to do its job
thanks for the link - but technically these firewires are not in spec and therefore may have higher error rates with a 100 Mbs stream - ideally we would need repeaters - any ideas?
