Firestore FS100 and 24PN problem
shadowe
Hi guys. I have two questions:
1- As I know Firestore FS 100 doesn't record 24PN frames, just does 24PA. If it's true what are you suggest (or another hardware).
2- While we are use Firestore, are P2 slots must be loaded with P2 cards or can be empty
Thanks..
Overcrank/60fps on Firestore???
Will it capture slo-mo (24p 60fps, which is a great feature of this camera) or do we have to still shoot to P2 cards??? I want to buy one, but I use overcrank a lot! Thanks for the info...
Supposedly Version 4 does variable frame rates, but I have never used it for that purpose.
Yes it will, and it seems to work fine. (I only tested it once.) You do need version 4 firmware, but it should come pre-loaded if you're only buying now.
