memeboy
Hi there folks,
I'm not having any luck getting the Avid to import the files using the "new" "File>Import P2 Card" option in Xpress 2.7 on a MacBook Pro.
I know that the format is correct, because after I did the 'P2 Organize' on the Firestore, I can use the older method of importing using the Media Tool, and that works, but I was counting on an easier workflow than that. I was under the impression that there was a smoother method of importing from Xpress with File>Import P2... Is there a thread that I've missed?
Any ideas? The setup that I've been using is HVX-200 shooting at 720/24P -> Firestore FS-100 (firmware 3.x) using P2 PN mode. That should yield a 720/24PN format file which then should be 'easy' to import.
Is my workflow wrongly thought out? Am I missing an obvious step?
Thanks for any and all replies! I will report back.
memeboy
memeboy
