Can you define "film"? Do you mean long-format dramatic production? I love my AC160, but it wouldn't be me first choice for a feature length production.
The small chips don't give you the shallow depth of field most people have come to expect in a feature length drama. I guess it's time we come up with another word for "film". Hardly anyone shoots on it anymore, and there's less and less distribution of film prints.
I know that in Canada, where I work, AVCHD isn't accepted as a primary shooting format by any of the broadcasters. So if you shoot a documentary for broadcast, distribution can be an issue. That said, I've been in the business for 35 years and I would say that AVCHD holds up as well as other codecs out there like XDcam 50 mbit, but the technical types who make the decisions don't allow it. The travel videos I shoot on my 160 aren't for broadcast, but I work with them like they are. Properly color corrected and laid back to HDcam tape, AVCHD looks gorgeous. I did tests with my 160 using a Black Magic HyperDeck Shuttle recording to ProRes. I had to look very hard to see any difference between the ProRes and the AVCHD.
I'm happy with both my 160 and my 150 for run and gun doc style shooting, both are very similar to the DVX100. I like the wide angle range of Panasonic cameras, Sonys are never quite as wide as I would like without an adapter. I also like the GH2 and GH3 for their versatility, I don't own one, but the footage cuts well with the 160.
So I would argue that AVCHD at 22mbit should be equivalent to XDcam 50, but the engineers have drawn their line in the sand and the line says 50 mbit.
That's why you render your final out as XDCam 50Mbps 4:2:2.
Ha! I'd like to but that would be breach of contract! You have to specify your principal cameras as part of your long form agreement with broadcasters.
Hi Zim,
I think there are two points here: Does the broadcaster accept 4.2.0 avchd? If so then your abilities, skill and talent as a" filmmaker" will be the only criteria. The 130/160 are capable of stunningly good output, with as much manual control as you might wish for.
And remember the 160/a can output 4.2.2 direct to a samurai or similar so it so versatile. Over here in NZ Sky specify 4.2.2 but having spoken to them about this , they have said that they have seen remarkable quality on 4.2. 0 and will happily broadcast it if the professionaism and artistic quality is there.
This cheers me greatly as I am currntly tendering for some TV commercials!
Cheers!
Rod
Thanks Rod, I'm not so worried about doing much commercial work. Pretty much just plan on indie/ documentary film. Plus some live music. The local PBS station here might show my last film and it was done with my DVX100b. Can the 130a output 4.4.2 too?
If you are worried then just get a 250 and no issues, no extra hardware to mess with? P2 4:2:2 AVCIntra 100
... To me, AVCHD is broadcast quality, but alas, not everyone else see's it that way.
Yes it can, but only through the HDMI connection, which according to Guru Barry's book, is really not a very rugged connection method. HDMI connections are quite fragile plug in connectors (I know , I easily ripped a socket off a HDMI lead by flexing it too far on a TV). Whereas the 160 has a HD-SDI locking bayonet type of connection which is far more robust. Also the HDMI does not output timecode but the HD-SDI does.
I believe the 160/a represents the best professional value for money out there and with every single aspect of adjustment available other than an interchangeable lens, is hard to beat. And bear in mind the massive zoom range of this lens- using this with radio mics for interviews very shallow DOFs can be achieved, (aalthough you need the space of course). It is a big camera though and substantial in weight for handholding too long. But it is amazing on tripod or steadicam. If funds allow, it is pretty unbeatable value for money.
Hope this helps
Cheers!
Rod
