Filming CRT TV's / Clear Scan Issue
EllipsisEnt
Hey All,
I'm having an issue that I can't seem to figure out:
I have a project where I need to film 9 separate old CRT TV's at the same time. I'm using an XH A1.
I knew I'd have to use the clear scan function to removing the rolling bars, but I've been worried that the different TV's will fall under different clear scan frequencies. So I plugged in 2 of the TV's and decided to play around with it. I was able to remove the first TV's rolling black bars with a frequency of 60.1Hz (the minimum I can go to on my camera), however on the second TV, I couldn't remove them at all. The best I can get is slow rolling bars at 60.1Hz, but they are still pretty dominant.
From what I understand, the clear scan function is more designed to shooting CRT monitors, but I didn't know if anyone had every dealt with something like this, knows a workaround, or if I am just kind of screwed.
Thank you in advance!
