proximity
Hey there, I hope someone has run into this.
When I bought the HVX, I didn't actually want to deliver HD products, and I still don't. But filming at DVCPROHD100 (which allows phenomenal colorspace, gamma depth etc.) compared to regular DVPAL makes a lot of sence, because I should be able to convert it down to SD, in for example the DVCPRO50 format and still exceed "regular" DV limits. - I tried this yesterday, just to check out how the workflow is. I wantet to check my CPUs speed, Quicktimes settings etc. But I where very suprised about the low quality.
I'm a PAL user, and have been capturing Extreme Martial Arts footage at 1080/50i, because thats all Final Cut Pro supports (in HD PAL). But, i'm actually working towards the most film realistic look I can achieve. But, I actually want to do SD, with very good colorspace in SD, pref. with progressive frames. (Naturally i'm deinterlacing the footage to convert it to 25p (or 24p) instead of 50i). But, when I did some pretty basic converting tests Quicktime, I found that the DVCPROHD100 (1080/50i) --> to --> DVCPRO50 (SD) looks competly horrible. Of course SD can't justify the detail of the original HD footage, but I even remember getting better results with H.264 than this.
So I tested that some more, and sure enough, H.264 (Full quality in SD def.) actually makes better looking footage than DVCPRO50 (SD). This is completly backwards because H.264 is not a workflow format, it's an enduser format. Which is not in any way suited for working with in FCP. The detail I get when converting to H.264 is sharp and crips, whilst DVCPRO50 looks very very smudgy and poor.
Can anyone please suggest what my workflow should look like to get the best possible quality?
- Proximity
- Proximity
