These thoughts come from the Perya thread but I'm posting them here.
1st Preamble:
Nothing in here should be construed as an attack on digital.
2nd Preamble:
I am not a film chemist, though I do have a chemistry degree, and read extensively on the topic (A while back now). In fact a film chemist probably couldn't say much more, due to commercial confidentiality.
1) Film is NOT ANALOGUE.
The nearest equivalent would be with high sampling single bit audio vs low sampling multibit recording. It can only be called analogue in the sense that there is a physical representation of the scene in front of the lens left on the emulsion. But that representation is quantised, just as digital is.
2) Organic Chemicals in film.
There are bucket loads, since without them an emulsion (Not technically correct) would be a) Slow, b) Probably unstable and c) only blue sensitive.
Let's enumerate them:
There are organo-sulphur compounds that act as speed enhancers.
Various electron traps
And most importently, Sensitisation Dyes, the only one I can recall is Erythrosine, but that is obsolete, the newer one are covered by commercial confidentiality, I think (I may be wrong!), but are needed to extend sensitivity into the green and red (Or even Infra-Red) regions, as well as increase the speed.
Colour couplers in colour film, which become colour dyes on development. The exception is Kodachrome (R.I.P.), where the colour dyes are added during development. the residual silver is usually remove during the bleach-fix step, except in a bleach-bypass look.
Obslolete film formats.
Any film can be projected. Since the film is physical, the frame size can be measured, as can the frame spacing, and frankly film projectors aint rocket science, any competent engineer could build one from first principals.
A side note:
Regarding the glass plates I printed, these were not umpteenth generation copies of digital files, but the same plates the long-dead photographer loaded into his plate-holders, exposed in his camera and developed in his dark-room, and which gave me a feeling of connexion with him.
Phew!
Sorry, had to get that off my chest. If you've made it this far thanks for bearing with me.
Dave
1st Preamble:
2nd Preamble:
A side note:
Phew!
Dave
