Hi there,
I know this has been asked a million times. However, I am very new to the community, and am having a hard time.
I recently picked up a T2i with a Tamron 17-50 f2/8 lens. I was in the market for the same lens for my T3i. However, I came across a whole filmmakers package on eBay for less than $700 (T2i -Lens,etc). It was a good deal, came with a Rode VideoMic and a 'Lensse - Steadicam Stabilizer' along with other little add-ons. Anyway, I found out that I have to send my T3i in to Canon to get repaired. There are some weird lines that show up during recording. And, also, the 24p doesn't actually work. Canon said it's still under warranty and I can send it to them for free.
Here is my dilemma, and was wondering you could help -
Most of the time I set my camera to:
24p
180 degrees Shutter Angle rule ((Framerate/(2*ShutterSpeed)) So, for 24p, I use ML at 1/47th as that's the closest to 180.
User Defined Picture Style
-4,-4,0,-2 or as flat as possible
Cameras, Lenses, Etc.:
T3i
T2I
Canon EF-S 18-55mm f/3.5-5.6 IS II SLR Lens (Plastic, Cheap, and Light)
Canon EF 50mm f1.8 (Plastic, Cheap, and Light) (Technically, it's 75mm due to the APS-C sensor.)
Tamron AF 17-50mm F/2.8 Aspherical XR DiII SP Lens (Glass and Heavy)
5x Batteries
32Gb Extreme Sandisk (Magic Lantern installed for T2i)
16 Gb Sandisk (Magic Lantern installed for T3i)
Lensse Stabilizer Floater
For the T2i filmmakers package, here is the link while it's still available: http://www.ebay.com/itm/251241709414?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
Lighting:
250 watt Home Depot Work light
500 watt Home Deport Work light
LED Home Depot Work Lamp (Just picked it up)
Audio:
Zoom H4n (When not used for capturing Audio for Video, it's used an external soundcard with Monitoring enabled, for better Midi-Recording.)
VideoMic
Mixcraft
Audacity
Sony - MDR-7506
M-Audio 88
Video Hardware:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130841
Product Number: 02g-p4-3653-kr A quick Copy/Paste into Google may help, or you can go here: http://www.evga.com/Products/Product.aspx?pn=02G-P4-3653-KR
I also bought a new Power Supply for my PC, to handle the new card.
Software: Here is where I have trouble.
Vegas Pro 12 64-bit
Adobe Premiere Pro CS6 (Fully Unlocked Trial)
Adobe After Effects CS6 (Fully Unlocked Trial)
Neatvideo - Trial (limited, with Watermark)
Gorilla Grain - Trial (Basic 16mm and such)
Film Grain - 35mm clean
My dilemma is: I cannot get a Film Look! I know I only have a B.S. in CIS, and missed my chance at Film School, but, this is what I want to do with my life. Where is the film look? Is it in the 'Cinematic' Presets? I thought it was supposed to be in the Filmic Fluidity (24p) in the capture itself. like the motion the actual video is recorded. I will put some footage out there soon. But, can anyone do a tutorial with your T2i/T3i from Raw to finished showing the difference. My footage is as flat and fluid samples that have been compared to, to the Canaon C100; the footage looks the same as my T2i. Is that normal for the T2i, and if so, how do I add that fluidity to it? How can I make this presentable for a shortfilm with that "art" look to it. I tried adding a Denoiser as well as adding Film Grain, even with the Trial versions, and they do not come out anything that I can present. The film grain I add is the 35mm clean; it's from the Gorilla Grain stuff, but was given to me, not the 16mm choppy stuff.
I can't seem to get that fluidity. Right now, to bring in revenue, I am creating a Food and Travel Web-Series. Until I can really get that "look" down, I am just working with what I have. I have tried two different bodies, and still the same look, is the result. I am saving for a BMCC, though, I am curious about the Red Scarlet, and using that for Digital Filmmaking.
I have been looking around for literature, books, tutorials, etc... about "why" the "shot" makes sense to the story. For instance, what the 'Rule of Thirds' actually is, why Wide Shots as opposed to Narrow, you know, basic cinematographer shots. None of that makes a difference though as to the "film look" I am trying to receive.
Oh, and I am learning Vegas at a slow rate, and Adobe at a slower rate. By doing this all myself, and I mean, literally all by myself, it's difficult to captivate everything I need to. But, once I do, then I can just guide someone else when I need to, when there is someone to guide. I would love to have a partner to work with, the way I've seen others, but I simply do not have that option right now. My wife does help when she can, but she works and is in college Full-Time. We also have two children, which are in PreSchool and Kindergarten.
Here is the point: I have all of the necessary equipment to get the right look and fluidity of "digital film." I have the proper audio capturing. I have enough lighting to pull out the sharpness I need. Most of the time the lighting is too bright, so I use the walls or objects around the room to bounce the light off and reduce shadows without overexposing.
How do I get that look I need? The 24p, is it really only in that? I don't really notice a difference in framerate, until we get to 60 or higher.
Thanks for everyone for everything, in advance.
Here is my YouTube channel:
http://www.youtube.com/user/AkersTimothy?feature=watch
24p
T3i
T2I
5x Batteries
Lighting:
Audio:
VideoMic
Mixcraft
Audacity
Sony - MDR-7506
M-Audio 88
Video Hardware:
Vegas Pro 12 64-bit
