File naming on Odyssey - same as on camera?
Clermond
is it possible that the 7Q writes the exact file names as the camera? I'd like to use the ProRes LT as Proxies and the 7Q files should be the same in name and duration. Thanks.
Thanks Mitch. Any plans for adding this?
As I shoot some slomos from time to time which the 7Q does not record von SDI - HD I have less clips on the 7Q than on internal media. With different names it's too cumbersome to correlate 7Q clips and rename them for proxy use.
Don't know about how & when this might get implemented on Odyssey. But do you know that you can change the clip number manually, and that once you do it will automatically advance from that point? On the Upper Toolbar, tap the button next to REC/PLAY that indicates the Clip info. This will open a menu where you can adjust this data.
Not currently.
Probably not relevant for Clermond, since I am assuming he is talking about a Sony FS7 + O7Q (?), but for the record: In my experience file names match when using a Canon C300mk2 or C500 and O7Q 4K/UHD RAW to ProRes mode.
Sorry, I should have been more clear. In fact, Odyssey is the ONLY recorder to properly support matching file names from the Canon cameras.
