GH4 : File Naming Glitch
Bern Caughey
Last week we shot extensively on two GH4s (1080p @ 100 Mbps) & the editor handling the transcodes noted the last clip on a card, & the first clip on the next card, had the same file name.
Hopefully this is a Firmware 1.0 glitch.
Are they still doing the incremental file numbers starting from 00000? What a pain. I so wish that they would just do the same thing Sony does and name the files with the date and time when the shot started. So easy to implement. :(
That sounds like a pain indeed. Renaming all files using their date/time is part of my ingest workflow which helps avoid duplicate file names should they ever happen.
This isn't a problem for me in FCPX. When the cards are imported the clips are renamed using the metadata. such a painless ingest process. It even knows how to place all the shots in chronological order if I shot on numerous cards which I usually do.
