Fiftypercent
Hi everyone, I'm new to both DVX and the world of the GH2 and I have myself stuck in a certain predicament.
Primarily im a new and recent GH2 owner and i've heard FD lenses are the way to go for a affordable yet quality solution. I myself purchased the recommend Cannon FD 50mm f1.4 lens and a Micro 4/3 adapter to match off of ebay.
Sounds great? right?
I can't seem to honestly get my adapter to fit onto the lens!
I've also purchased a canon EF mount adapter and that seems to be working great (minus the aperture never closing)
So heres some of the things i've learned and maybe someone on here may have a solution to the issue I'm facing.
The lens I have is one of the "old mount" lenses with the silver twisting ring at the bottom.
I've tried mounting the lens while the adapter was both on the locked and unlocked points
I've tried mounting the lens while the silver breech ring was turned both all the way clockwise and counter
I've tried adjusting the levers in the back of the lens into various different positions to see if that would dove the issue. no luck.
i've tried turning the aperture to the lowest and highest values and still have no luck. (P.S. my lens close down further then f5.6 don't know if that means anything)
i've tried holding down the button near the green A, and still have not been able to fit it.
Maybe I'm lacking some serious technical skill here, but hopefully this is a "You don't know, what you don't know" scenario and not me having a defective lens or adapter.
Pictures of the Lens and adapter included below.
On the first picture I also circled a part of the lens that I can't seem to get to fit. Every time I try to attach this lens, the part where that piece is sticks up and I can't figure out how to get it go down/ or line up correctly.
Any advice give is appreciated
Thank you in advanced.
