FCP X Ingestion issues, anyone?
dtzfilms
I decided to try FCP X and to my utmost dismay and chagrin - the bloody thing won't recognize my AF100 footage!
Is this something everyone is experiencing or is this just me and my usual idiocy? Is there a work around?
I would copy the folder contents of your SD Card to your computer for a backup and get 5DtoRGB. It's TOTALLY worth it. Convert using the Rec709 preset, Full-Range and let'r'rip...
It shouldn't have any problems ingesting into FCPX or seeing the card. But l agree with Kyle, using 5dtoRGB is a great way to convert af100 footage at the settings he suggested.
Why in the name of Whatever would Apple make an NLE that still requires one to buy another program before it works when earlier versions FCP 6 & 7 can edit AVCHD??? It's infuriating!
I've got the card on my external hard drive already and it just won't see it. Footage is quite visible in FCP 7 though.
I see 5D2RGB free but the download link doesn't work. Man, this is frustrating! Why can't FCP X see what 7 sees????
I just answered your question in your other thread. Make sure you copy ALL the contents of an SD card and then open the archive form the new folder you created. The card structure need to be there in order for it to work correctly.
I edit AVCHD in FCPX natively all the time. There is no problem with that. But, on certain projects I use 5dtorgb because its a great conversion into prores. FCPX has handled everything I've thrown at it no problem. The second I insert the card into the card reader, FCPX's import window pops up.
Like Dustylense I've had no issues with AVCHD & FCPX - just insert card and the import window pops up.
I'm previewing and editing in no time.
As with a few members above I'v had no issues with FCP X and AVCHD but why 5DtoRGB I can understand using it for legacy versions of FCP when Quicktime had the occasional glitch but my understanding is that FCPX was built on something called AV foundation (I'm not an expert by the way if Ben is around he can clarify).
So what is AV foundation and what is its relationship to Quicktime ?
Does AV foundation do a better job of transcoding AVCHD to Prores than Quicktime ?
I have just downloaded 5DtoRGB and i will play with it shortly comparing it to FCPX own transcoding.
EDIT after a bit of Googling... AV Foundation will eventually replace Quicktime but thats way off in the future, its a more efficient/better/clever way of handling video and the new Mac OS is built on it as id FCPX, but quicktime ain't going anywhere soon. Now back to the original question does AV Foundation do a better job of transcoding than 5DtoRGB ?
In FCP X remember to open the footage as a camera archive (you'll need the files to be in the original card directory structure). It won't open the individual clips as files. This is mildly annoying, but copying the whole card file structure is good practice anyway and once you've remembered that it is "Open Camera Archive -> Open Archive" not File Import, it seems to work fine.
Cheers, Hywel
I have no problem "importing from camera" when the CF card is inserted in the slot in my iMac.
I also have no problem editing and monitoring perfectly through my MX02 to SDI pro monitor with the latest Matrox drivers and 10.0.4, without transcoding or using proxy footage. It will stutter some if you start to edit before the files have finished copying to the RAID, but you can easily start to find the good shots and set up the favourites and keywords while the files are imported this is a huge time saving. I can also do this with my 2 year old MBP in the field. Although the playback on that does not work as well unless you use proxy or "better performance" settings.
I do have the 2GB graphics card and the 3.4MHz I7 with 16GB ram and a TB RAID.
This system runs circles around my 4 year old 8 core MacPro. And it makes FCPX a joy to work in. It is great to work with AF100 footage w/o having to transcode, it also handles XDcam footage natively once rewrapped, big space savings and no lowering of quality as everything is exported as ProRes or directly to whatever type of compressed file you like.
No problems here With FCPX and either AF 100 files or AVC Intra files. Insert card> FCPX window appears with clips added from card volume and I'm rolling. I'll admit I'm new to FCPX and really haven't edited much yet as I'm in the "getting to know you phase" but I have been playing with different panasonic flavored files and it really couldn't be easier.
I think a previous comment about whether the file structure of the copied card volume is correct might be applicable.
It's somewhat frustrating, after achieving a modicum of competence in FCP 6 to now have to flail in the wind for such moribund tasks as closing a project to work on another. Does anyone, praytell, know how to close a project and work on another? I'm editing two projects side by side in this marvelous new X, but I can't see how to close one project down so I can compile clips in another.
I put a rough timeline together in X lighting fast though, first nice thing I have to say about the program and the background rendering - very nice.
EDIT: Figured it out. Man, this program is so esoteric. They should have a comparison list, you know, a list or a T-chart of things that have changed, just to give us a running start.
I have no guidance about FCP X. I'm at the stage of roughing things out which is very fast I agree, but the fine details take a bit to work out. Still no problems with ingesting file based material except for he fact that the Help menu in terms of camera compatibility seems pretty outdated.
Case in point: I went through the compatibility menu to see if AVC I was compatible but got no result , yet AVC I plays fine in FCP X.
Think of FCPX as flying an airplane versus driving a car.
It is very different and gets there in a totally different way, but you get there way faster except if the weather is bad. You need a new computer and fast drives as well as lots of ram and a fast graphics card.
Actually the learning curve is not as severe as getting you private or instrument license. But the best thing is to get a course like Lynda or Larry's.
