Serge Gregory
Log & Transfer in FCP 7 hangs when I select a "longer" file--in my case more than 30 seconds of 1080/24p. It will not appear in the L&T viewer, or the top half of the image appears in the viewer with the bottom half green. If I try to go ahead and transfer the file, I get an error message. I thought it was a RAM issue, but when I upgraded to 6GB from 2GB, it didn't make any difference. I'm running a MacPro. The Private folder I'm logging has a lot of files (over 150) and I don't know whether that's taxing L&T. I'm having no problems with shorter files in the folder that are less than 20 seconds long.
Has anyone experienced this? Will using Toast to do the transfer to ProRes 422 get around this problem?
