FCP 6 Preference Files Playback Issues
I have been editing with the same version of FCP 6 pretty much since its release. Recently the playback has been acting up to the point where editing has become nearly impossible. I cant watch any of my sequences for more than three seconds. I did some reading on the subject and read a lot about trashing the preference files and cleaning the disk. So, I go to trash my preference files and to my surprise there is no such thing. Also there is no folder labeled Final Cut Pro User Data, which I am supposed to find a number of files to delete.
Is this the problem? I don;t understand how I don't have this file. I even did a search for it and nothing came up.
I'm sure others have had playback problems on FC, what exactly did you do to solve this issue? I am about to order more ram for my mac and hope that works.
Also it is not the hard drive because i opened a different project from a different drive that contained the project file and media, and it does the same thing.
I'm confused, please anyone help........
Edit:
Ok, I found the files and trashed em. It booted up and did it's thing, I then followed someone else's advice and re-rendered the whole project. Nothing........ Secondly I have been editing through a USB splitter going to five hard drives, the files are not spread out on all five though, there only on two drives. Anyways, I unplugged them from the splitter and sent them right into my computer through firewire. Still not working.
Now what happens is it comes up with an error message that says this
"One or more frames were dropped during playback. If this frequently occurs, try
- Turning off Unlimited RT
Lower my compression data rate
Close open sequences
Lowering the preference for real-time audio tracks
-Increase the speed of my system and/or disk drives and/or network connection
it adds in red colored ink....
RT Extreme determined that it was caused by "slow discs" and that I should try:
-Increasing the speed of my disks
-Decreasing the number or RT layers
-Limiting my RT bandwidth in User Preferences
What could be the cause of this now?
Macintosh HD>"User" (your user account)>Library>Preferences.
You'll find a file named com.apple.FinalCutPro.plist.
What computer, Firewire drive enclosure and drive mechanism, sequence settings, and video specs are you using?
And please, USB is bad enough, but using a USB splitter to edit video should never be considered.
Well i have been editing projects with my spiltter and usb for months, pretty extensive projects actually. It still happens with my drives going through firewire now, lacie terabytes. Computer is an imac with 2 gb ram, editing footage from the 7d converted to prores. Could it be my ram? Im still lost.
You've been editing Pro Res multi stream HD footage off USB drives off a USB splitter for months with no issues?
That's amazing. Whether that will work long term is another issue as your post indicates.
Sequence settings please, and video clip attributes. What version of pro res? How many streams?
How full are your "lacie terabytes?" How many terabytes for each drive? Are they daisy chained?
FW400 or FW800? 7200 rpm or 5400 rpm? How old?
USB drives use packets instead of streaming data like firewire. This is the main argument for using firewire over USB for editing audio and video.
Definitely need to know what format or flavor of prores your using to edit (prores, prores hq, SD, HD, frame rate, etc...) but in general it can really require some quick drives in order to playback smoothly.
I think the only reason you may not have seen any issue is the use of dynamic video quality or dynamic frame rate to during RT playback. Is this the case?
If you do a google search for ProRes White Papers, you'll find the official info for apple prores and the data rates that it requires for smooth playback. Typically you'll need 6-9MB/s (that's mega bytes not mega bits...big difference) for ProRes or ProRes HQ standard def. For 1080 HD it can be anywhere from 16-62MB/s. It all depends on frame rate.
Most people that are editing multiple streams (layers or video tracks) are going to need some kind of internal or external RAID system in order to strip several disks together and maximize their data throughput. If you've got a drive or drive system that can sustain 200MB/s of data read/write then you should be able to playback 3 streams of 1080p59.94 ProRes HQ.
More info needed...
