FCP 6.0.5 - Error: Unknown & No Data
Jordan Berry
Howdy,
I've got a BIG problem. Last night I was encoding a wedding to ProRes and it stopped about 3/4 of the way through. Some clips were left with little red exclemation points next to them that read "Error: Unknow" or "Error: No Data". One of these clips was my big ceremony clip from my camera. I was able to try and push the ceremony clip through several times and finally get it to work.
- I ALWAYS reformat my cards in camera before every wedding.
- I immediatly copy the cards to multiple eSata drives.
- I never delete clips or alter structure in camera or otherwise.
- I always check the the data on the HD against the data on the card.
- My cards are always handled carefully and immediatly put in a waterproof case.
- I shoot on the SandDisk Extreme Cards. This card in particular was a 16GB.
- I have 2x Plugins installed on FCP. Magic Bullet 2.5 and the flashframe transition.
I remember this came up for a clips on my last wedding but I was eventually able to get them through. I've trashed all my preferences, and cache and tried again. No difference. I've set turned the audio to Stereo instead of Matrix in the LOG & TRANSFER window. I've unchecked the remove pulldown checkbox. (After googling creative cow suggested I do those). I'm lost on what to do now. This isn't the end of the world since I have time to mess with this. However, on a SDE I CAN NOT have this happen. It will be the end of me!
I tried encoding with AIC and it worked fine. Then I tried ProRes after restarting FinalCut several times and it works. It's obviously Final Cut and not the media.
Please, I need to fix this immediatly. I have a SDE in a week!
Do you have Toast 9 or 10?
Or VideoPierHD
Or VoltaicHD?
These are alternative mts conversion programs and if this is critical data, you might consider at least downloading the demos for that latter two.
