So you have tried the top and bottom viewfinder ports? with 20-A the results will be the same with any it's not your viewfinder? Yes the Test port is SD video feed, you can get RCA bullet and use with any old tv.
You don't get characters on any of the 4 above?
No luck with the SD output either so that crosses off all 4 side ports and 2 VF ports.
Try this for fun:
Turn on the camera. Push Rotary Wheel Once, spin rotary one click either clockwise or counterclockwise, push rotary again.
Press Menu Button Once. Click Rotary, spin one click either way, push rotary again. Nothing?
Have to charge batteries again but I'll give this Konami code a try. Is this a reset code or a blind trip through the menus?
