J JWinter Well-known member Sep 15, 2009 #1 is this common? false "failed to copy" ? I did 2 offloads using Compare and both time said all clips failed - but none failed.
J JWinter Well-known member Sep 19, 2009 #2 no one else has had "failed to copy" result when using "compare" in P2CMS? (even when operation did not fail)
J JWinter Well-known member Sep 24, 2009 #3 panny said reinstall drivers....ugh... shotput does not report errors so i will just use that i suppose...
