No, all variable ND filters are made of two polarizers. That's the only way that it can work. In fact, Singh-Ray even warns that rotating the ring beyond the specified range will result in color shifts and the "crossbar effect."I imagine those are just solid NDs that change only the overall amount of light as you dial- without affecting the color spectrum and reflections as a polarizer does. Sort of like the difference between polarized and non-polarized sunglasses.
Noah
Ok, so are they a circular and a linear? Or are they both linears?
And, could you take it apart to use as a plain pola (for less light loss)? I guess not but might as well ask.
From the thread in the 5D forum:
My variable ND solution is DIY. I use a low-profile Marumi 82mm circular polarizer (this one: http://cgi.ebay.com/Marumi-82mm-Cir...ters?hash=item4ceb17eb78&_trksid=p3286.c0.m14) with a Hoya 82mm linear polarizer (here: http://cgi.ebay.com/Hoya-82mm-LINEA...ters?hash=item35a38736fc&_trksid=p3286.c0.m14) screwed on top of it. When fitted on my 28-75mm zoom lens with 67mm filter threads, there is no vignetting from the filters at 28mm. (This is on the 5D.)
The DIY will perform just as well as the Singh-Ray and the Fader ND. It's also more difficult and inconvenient to use. But it's cheaper, and it allows me to control polarization as well, because I have two rings that I can rotate (linear polarizer's ring is for controlling.
