GH2 Fader ND, shoot in full sun wide open
has anyone shot with the GH2 and the F0.95/25mm in full sun wide open with one of these?
Yes, using a Genus 52mm Fader and the 25mm f/0.95 Nokton.
The only issues are:
1- Most fader filters tend to warm the image, so you may need to color correct, or set your white-balance with the filter in place.
2- The polarizing effect can make peoples skin look "flat" because the "sheen" is often gone.
I plan on buying Tiffen ND kits as a back-up for my fader filters because they do not suffer from either of these issues.
Tiffen 52mm ND Filter Kit : $42
I have a shoot this week and I'm going to do that with the voigtlander. I've used it in that combination but not outdoors. Mostly inside to cut down the light and narrow the DOF
Thanks guys! First post came from someone I've met before. Wild. I also just talked to someone who said watch out for vignetting.
