I think I remember you saying you never used the Cookes on the F65. Is this still the case? If so, why? Im curious about the pairing of F65 and Cooke, so wanted to get an idea from someone with experience...although this could be anyone on the forum, as well. -All the best, Rafael
James,
Three questions.
1: What evf do you recommend with the F65? The F55 OLED? Others? I imagine this is not a camera specific questions since PPI is important, but I figured you might know of something that plays well with menus and other considerations.
2: I think I remember you saying you never used the Cookes on the F65. Is this still the case? If so, why? Im curious about the pairing of F65 and Cooke, so wanted to get an idea from someone with experience...although this could be anyone on the forum, as well.
3: Have you figured out any way to separate the recorder from the body...say, via a wire?This could be helpful for steadicam work.
Lastly, thanks for creating this thread and taking time out of your day to answer questions.
F65 is very different from the sensor perspective than F55 - more pixels for a more accurate color reproduction and a different (slanted) Bayer filter. It's not 8K, which is ~ 33 MPX with the standard Bayer pattern, but it's arguably the best looking 4K camera there is.
They share a lot of the same technology. The F55 uses the same CFA as the F65 and both capture a much wider color gamut than rec709 (F3/F5). that is more like rec2020. Obviously the F55 is not 8k and getting 'full color' without interpolation like the F65. Both are global shutter cameras. The F55 does not use a cut down F65 sensor, but it has more in common with the F65, than the F3/F5 sensor.
There is a lot of R&D going on on how to make the RS closer to GS. The "easiest" one is the faster sensor readout. Other are attempting to go halfsies and produce half a sensor in RS and the other half in GS. I wonder if the new URSA Mini sensor has that feature, since it is switchable with (... a 2 stop?) loss.... this is pure speculation but I believe this is why the Bm4k suffers compared to the 2.5k - a lot is sacrificed to get that global shutter.
