F65: F55 vs F65
JMtheDP
I will have an F55 in my possession for a couple of days, maybe a week in the very near future. If anyone has any specific tests they would like me to perform please let me know!
JM
I am going to get some candles, put on some Barry white, I am hoping they will produce more.
Jesus... I think we know who the 'man' is in that coupling.
That photo actually makes me feel much better about not snapping up the F65 I almost did - the thing's a behemoth!
Don't be too quick to judge. The F65 is fully loaded in that shot, and with a lens twice the size.
When I was at Sony last year they had an F55 set up, and with the RAW recorder and everything on it was just as long as the 65.
I have accessories and things on the way shortly for the 55, I am helping a University build a camera kit, once it is all fully built I don't think the differences will seem so vast. After all, even the F35/F65 need a riser plate to get the bottom to the right height for an ARRI Bridge Plate.
It is worth noting the resolution/frame rate differences between the cameras, at least:
F65
1-60 FPS
All modes available - 8K RAW, SR codecs (up to 880mbps, 4:4:4, 12-bit)
61 - 120 FPS
F65 RAW HFR only - SQ Codec, but half the resolution. So effectively a 4096 x 2160 sensor. Does not crop. Deploys a special OLPF to avoid moire/aliasing.
F55
1 - 60 FPS
All modes (4K, XAVC, RAW, etc)
60 - 180 FPS
2K only (either full scan with line skip, requires optional 2K OLPF for no moire, or centre crop)
Records to XAVC internally
180 - 240 FPS
Supported only by AXS-R5 recorder, in raw mode
I am personally of the opinion that the F55's 2K picture is NOT sufficient for HD production. If you need to use it for a speciality shot here or there, that is fine, but if you are shooting either line-skip or crop, I would not consider this even a 2K camera - let alone 4K.
For the F55 are you talking about the 2k crop mode or 4k down sampled to 2k? With or without the appropriate OLPF swapped in? I'm curious why you don't feel that 2k out of the F55 is good enough for HD production?
Harry
I am talking about the modes where it is generating "2k from 2k". Ie, "full scan" HFR, or "crop". The normal 2K mode, which samples the whole sensor, is fine.
It is not an F55 specific issue, more that with a bayer pattern sensor I believe you need really 50% above the intended format to produce a pleasing picture. I am pretty sure a 2K bayer pattern only resolves something close to a 720p picture, not a 1080 one.
4k bayer patterns for a 4k image get away with it because they display a picture which is generally considered "high enough" resolution for a nice picture. Even though the actual resolved resolution is usually somewhat shy of the headline figure. 1080p/2k is a different story.
It is not an F55 specific issue, more that with a bayer pattern sensor I believe you need really 50% above the intended format to produce a pleasing picture. I am pretty sure a 2K bayer pattern only resolves something close to a 720p picture, not a 1080 one...
20/25% loss to ~ 800-850 ("But we can then upscale it!", says ARRI), depending on the cam.
4K off a 8.8 MPX sensor might give you ~ 1500-1600 or so, closer to 2.7K in reality ("But we can upscale anything!", still says ARRI).
PS. On most monitors/TV screens up to and including most 4K projectors, it's pretty hard to tell 2.7K vs. from 4K at any distance.
Harry
I see your point, but that really doesn't make it any worse than something like an F3, which is straight HD. If anything it's a tad better, because you're getting a few more pixels at 2k
I've actually had to soften the image out of my F3 on a few occasions, because it can be pretty unforgiving on faces shot with modern glass.
I have a theory on why the mildly upscaled image out of the Alexa looks so good. In visual effects and matte painting we will often scale CGI or a painting on purpose to remove some of the 'digital curse'. Matte painters in particular have used this trick for a long time to remove brush strokes and make the image 'gel'.
Maybe the internal upscaling of the Alexa image has a similar effect. Whatever the phenomenon is, it is it sure as heck look great. :-)
I agree that you need a really good set of eyes to tell the difference between 2.7 and 4k. From a few feet away your eye doesn't even resolve high enough to pull that off. Even closeup it is quite difficult and I would say that all bets are off with a moving image. You'll probably see something of a difference if you flip back and forth between the two images still at high magnification and know what to look for.
You need a great set of eyes to tell the difference between good HD and 4K!
But that's not the point. The point is all the numbers manipulation just for the sake of marketing.
The F3 was 2448 x 1377 resolution. An odd number, but appreciably higher than 2048 x 1080 from the F5/F55 in those modes.
Maybe the internal upscaling of the Alexa image has a similar effect. Whatever the phenomenon is, it is it sure as heck look great. :-) ...
My theory is that it is upscaling from an already high res - assuming the open gate, which is around 5.7 MPX into 8.3/8.8 - which is sort of like accelerating a plane from 500 MPH to 600. It's very hard to tell the difference from Point A to Point B there vs. going from zero to sixty quickly.
