Thanks for the suggestion hunter, I will have to try that out. I am designing a new interface box with my machine shop guy so I will have two parts I need to paint black to match. It is just a metal plate about an inch thick, the ca joint screws into the back. The plate is hollowed out in the center with a space to mount the little circuit board needed for the dual SDI output and the two SDI plugs come off the side, then on the back I will drill mounting holes for the battery plate. Basically I am going to replace the hyper deck with this smaller interface box in my setup.
Probably overkill for what it saves I just think the interface box is awkward and filled with empty space. My goal is to get 12 bit out without making my rig any larger. I don't need the audio inputs or 12v power input so I am ditching them and just keeping the parts needed for the SDI which is very little. I'll post pictures once I get the thing together.
