I was thinking about the A1 and shooting in general and I see this topic a bit and reference made to the zebras. Zebras are a good guide to ensure your not getting hot spots but they shouldnt be used to judge your overall exposure.
For example you may have a scene with talent and you expose their face perfectly - thats what you want - but you are overexposed in other areas of the frame. OK so here is what I am actually doing - this really relates to run and gun not studio or where light set ups are practical. Shooting imgagery around town, gathering stock footage etc.
A frame with a person or object:
I zoom in on the object or person and check the exposure meter. I then stop it a fracton higher on the meter. You want the object or person to have the correct exposure.
I zoom out. At this point I may have zebras in other parts of the frame. At this point you have some options and ill assume you cant get anymore light to key your object or person any more than they already are.
First, can you move the person or object? Yes, then do it. No, see second.
Second, drop your exposure by one stop. You will still retain detail on your object or person and increase the detail back to the overexposed area.
Three, live with it. If the overexposed area is small in the frame then its rarely a sightable issue. An Example below.
Shot explanation. Shot in 1/3rd shutter speed at 24f. Shot was designed to speed up to 5000% in post, thus the large amount of motion blur on anything moving. In this shot I wanted good exposure in the crowd as they cross the road and the building fronts with the screens.... no its not soft focus, motion blur. As you can see to do this I am overexposed in other areas. Cant move things or cam position. The reality is however this shot is totally acceptable. I might run a broadcast safe on this small shot to ensure im good, or manully adjust with scopes. I prefer to use the scopes. NO CC. In the actual shot with such movement in the crowd and screens its much less noticable. will pop up a QT in a sec to show what I mean, in the QT I will add a fraction contrast - only in the blacks i think. OK done heres clip very compressed but you can see what I am talking about... check image below first.
http://www.scarlet-films.com/A1/exposure.mov
