This was recently discussed in the low-light banding thread, but I think this post was the first to identify some unexpected behaviour with exposure compensation
http://96.30.23.131/showthread.php?p=1652245
In brief, in Creative Motion Picture shutter priority mode, if you have shutter speed set low and ISO on 1600, and it's dark enough that you can be sure aperture is already wide open, using exposure compensation you can increase the brightness of the video significantly. I think it may be intelligently turning on "night mode", which can be used for video in that scene mode, and I wouldn't be surprised if that involved monkeying with noise reduction settings on its own too.
In the same scenario, you can't actually use exposure compensation further to darken the video when it's already underexposed - it has no effect. Again, it's using its own intelligence.
I've since been testing exactly what exposure compensation does in various scenarios and it's not straightforward. If you dial in some negative exposure compensation in a medium scene, then point towards something brighter, then put the exposure compensation back to the mid point, the video does not get brighter. It seems like the compensation gets reset when the incoming light changes. The opposite is true as well, ie make a light scene darker with ec, then point towards darker area, brighten ec, video does not get brighter.
This seems to me another example of how there's no real manual mode with the GH1 - or probably any such device, as it's all fly-by-wire and what you set is filtered by the firmware, which can choose to do what you ask or do something better if it thinks it knows best.
My car's auto gearbox is much the same - it can be switched to manual, but if you don't change gear when accelerating, eventually it will do so itself to protect the engine.
Anyone else noticed anything unexpected about the way exposure compensation works? Could this be to do with the claim that GH1 ISO can be much higher than the value set?
