Yes in general, but it depends on the situationDoes the rule expose to the right still apply?
Let me rephrase this
When using custom flat profiles, normally you expose as far to the right without clipping.
Should you do the same with Clog?
Use View Assist and expose to the right.
Would exposing 18% grey at 40ire as stated in this article using this art adams color card still be the same?
We expose at -1 stop with C-log. Exposing to the right is not a smart thing here. The -1 stop gives 99.7% usable results after grading. Could be our C300 but the highlights go hot very, very quickly when exposing correctly thru waveform...
I would imagine that these ideas and practices would translate across to the C100 as well?
There is noise in a C300?In theory middle gray should be 32%IRE, but I generally lift it a little from there to avoid noise in the shadows.
