DavidBeier
Ok, I'm currently working on a project in Avid Xpress Pro HD 5.23. I shot it on the DVX100A in 24p. As this is the my last SD project before I move up to HD and there is such little resolution to work with, I'm trying to go ahead and get as much quality as I can.
There are several shots that will require some compositing. Stuff like drawing matts, keying out things, compositing two images, and making some sections of the image in color and other in black and white. For these I've decided to go ahead and use discreet combustion 4.0.
I captured the footage in standard DV25 since the DVX100A is mini-DV anyway so I wouldn't lose quality. I've found most of the clips that need outside work and am trying to export them.
However, I'm wondering how I should export. I've been doing a number of tests with weird results (all using quicktime formats).
If I export them "same as source" or "quicktime refernce" the file looks pretty good when I play it on quicktime but seems to be missing the nice crushed blacks I worked so hard to get. If find this odd as it still looks crushed in the Avid monitor. Also, when I try to import these files into Combustion they look REALLY blurry, far lower resolution than they did in Avid or in Quicktime. Why?
I've tried the DV/DVPro setting with the quality at "best" but that also produced odd results. The blacks still were hazy when I looked at it in quicktime but where perfectly crushed in Combustion and very sharp.
The Avid DV100 codec looked great in quicktime but ran very slowly and didn't show up in Combustion (looked like pure black).
Finally, I tried uncompressed quicktime which, of course, looked fantastic in both Quicktime and Combustion but took almost 1 gig of space for a 30 second clip!
What's the best setting to keep the highest quality? Is there anything I can do in Avid or Combustion to retain quality? How can I ensure the highest quality not only when I send it back from Combustion to Avid but also when I go ahead and want to print my Avid project to tape or export to a DVD?
