My first post here, here we go!
I just saw the thread about focal reducers today, pretty cool stuff imo! Read through some replies and saw that someone mentioned you could use biconvex lenses (I think at least
) to reduce the FOV. I didn't give this too much thought at first, but then I remembered I had an old Jag35 35 mm adapter, with biconvex glass in it. I took it out and started playing around with putting it inside my EOS>m43 adapter, turns out it works. There's a small problem tho, the distance between the glass and the lens is too small and causing everything to be blurred. Here are some pics with the standard 18-55 EOS kit lens, at 18mm.:
This is with the glass inside the adapter, it's wider but also blurred.
This is without the glass, not as wide. Blurred, but this is because I didn't bother to focus properly.
I am out of ideas for now, so I'm turning to you guys to see what you have to say. I was thinking that extending the adapter somehow would work but I have no clue how to do that.
Peace
Update:
Just realized I don't need to extend the adapter, but to shorten it! I will have to sand it down about 1 or 2 mm to be able to focus to infinity!.
Update 2:
Started sanding down the adapter now, I think I might have to sand it a tiny bit more in order to get the sharpest image possible. But I'm getting there!
Focus ain't quite right yet, but soon!
Close up of my dog, no problems here.
Peace
Update:
Update 2:
