GH2 EXCLUSIVE Noktor 12mm 1.6 on GH2 !
seb33
MFT Wide and Fast !
Noktor / SLR Magic Hyperprime 12mm f/1.6
The Daylight tests
I've just received this afternoon from SLR MAgic their new wide and fast angle, a 12mm f/1.6 (24mm in 24X36 eq.) in a Micro Four Third mount.
This is, to my opinion, an incredible lens, fast and wide, and there is no visible distortion. The focus and aperture rings are very smooth. It is all made in metal.
XXX There is in my test a small vignetting in the outside shots due to the use of a 62mm L.C.W variable ND filter (with a 58mm/62mm step up ring). To avoid the vignetting you'll need a 67mm or a 72mm filter with the right step up ring, because remeber this is a wide lens ! I'll try with this combination later XXX
-The lens has 12 aperture blades like cinema lens.
-The 1.6 is a T stop aperture, eq. to f/1.4 aperture !
-No visible distortion and optical correction instead of digital so people look normal at edge of photo.
-No vignette (you'll need a step up ring for filters...)
-When macro the lens is 3cm from object only !!!!
The 12mm lens is a whole different lens than the Magic Toy 11mm. it is a lot better but at the same time it is not the same price. it is $500 US. it is very creative but has good performance as well. Macro ability is amazing on this lens.
- Lens length 2.92 inches
- Front filter thread 58mm
- Weight is 325 grams
In EU and US the lens will be SLR Magic HyperPrime 12mm F1.6 with a SLR Magic black ring. (TBA. around End November or December)
In other parts of the world it will be the Noktor HyperPrime 12mm F1.6 with the Noktor green ring -the one I'm using for this test (available in October)
From Andrew from SLR Magic : "It had been a big challenge designing this lens and living up to the Noktor Ultra Fast Lens name. F1.6 is the largest aperture we can get this UWA lens to go. It works great indoors but flares when there is strong light. When you stop down to f2 there are no more problems. It was a debate for us if this was a good decision or not. Making this lens F1.6 with some flaws or make it F2 or F4 with no flaws wide open but smaller aperture."
GH2 24P
Nostalgic mode
Noktor / SLR MAgic Hyperprime 12mm f/1.6
Apertures between f/1.6 and f/5.6
L.C.W Mark II 62mm ND variable filter for the outsides shots + step up ring 58mm to 62mm
Shutter speed : 1/50
Seb, F1.6 does not look as bad as I thought it would. Thanks for another great video test and I think I will get this instead of the 12mm F2.0 Olympus.
Joe
Where can we buy this, and when?
When you're outside, what's happening in the bottom left of the frame? I know you said there's a vignette due to a filter but it's a white vignette there and not elsewhere.
I don't know maybe a reflection between the filter and the lens. Closing the iris reduce flares.
As an avid C-mount experimenter,
No.
I'm agree with you mcbob :) Fruitypurple, are you working for Olympus ? ;) Me I'm not for SLR Magic, that's for sure ! After testing so much C-mount, Voigtländer, Panasonic, Nikon lenses and so on, I know a little what I am talking about... :)
No.
HERE THE answer of Andrew Chan, Product Manager from SLR Magic :
"It is not possible to keep light
loss to such a minimal from teleconversion. It would result to soft corners as
well. We made a survey on dpreview forum asking what the most wanted lens for
micro four thirds was. Everyone voted and this was what they have requested for
us to design. This is an all new lens design and not converted from anything as
you said. 58mm filter thread was chosen so that there is no lens shading from
internal flash of the G3 and GH2. The front is large for optical distortion
correction and large aperture. It is a very common design for MF wide angle
prime lens."
Seb,
Good to see you at work again and to watch your ever patient and helpful petite assistant growing up. And thank you for the videos. There is much there to enjoy.
My main issue with the lens is its color rendition. I played with the lens for several hours and while some video footage looked great, a lot of it looked "washed out". I seemed to notice a similar effect in your footage. It also didn't respond too well in the ETC mode.
The Olympus on the other hand, although substantially more expensive, makes the images pop, big time. I put it down to their experience with lens coating. And it performs very well in ETC mode and of course will provide auto focus if required. I seemed at times to struggle with focus on the SLR lens.
Having said that, the SLR lens comes in at a more palatable price point and the non distorting optics are indeed a marvel. Add two additional stops over the Olympus and I believe many will be happy. I'm passing however for the first reason I mentioned.
Best wishes,
Jurek
Seb,
Best wishes,
Jurek
Thanks for your impression Jurek. Tomorrow normally my local photographer has the Olympus, I'll try to do a fast test between those two lenses.
